3 Simple Ways to
Share What You Make
Other ways to share:
© 2012 Instructables
All Steps Viewing
OK, that being said, my next question is this: Are you going to build an Antenna or are you going to use a USB WiFi adapter with some sort of reflector? Your choice will make a huge difference.
If you go the USB adapter route, don't expect too much. All you're going to do is make some sort of rear-reflector for a simple 2-element beam-type antenna. Some moderate gains can be had with this method.
If you are wanting to build an actual antenna, like the real Cantenna (not the USB version), expect to invest some of your time into the building of these as they do involve some work and a little math but the gains are worth the work.
Also, don't forget that any real Antenna is just that, an ANTENNA! Nothing more. You will have to figure out how to connect your newly built antenna to your WiFi adapter and how to mount it for best performance. Tripods are very handy for desk-side testing.
The type and configuration of the antenna are up to you. Good Luck and have fun!
But do get the ARRL handbook. It will pay for itself!
