Step 4Time for surgery.
Using the green tracing as your guide, cut away the parts you've highlighted as carefully as possible. You're not just cutting by tracing once over the each mark once.
Instead, you're cutting out the width and length of the green highlighter line. Use the blue breaks as hard stops to tell you where not to cut. This will leave you with several little 1/8th inch wide slivers of paper.
Tedious? Sure, but the end result is worth it.
Add Comment
