Calculate Drill or Lathe Speed
6,100
134
5
Published
Introduction: Calculate Drill or Lathe Speed
If the pulley RPM on your tool is not labelled you can calculate it.
Step 1: Measure
Measure the radius or circumference of each pulley. It doesn't matter which, as long as you stay consistent and the inside and outside diameters of all the pulleys are proportional. It is the ratio that matters here.
Step 2: Motor RPM
The motor should state the RPM. Use this to make your calculations.
Step 3: Ratio
Divide the motor pulley measurement by the measurement of the pulley the belt connects to. This will be your ratio. Then multiply this ratio by the RPM of the motor.
Example:
motor pulley radius=2 inches
follow up pulley radius=4 inches
motor RPM=1000
2/4=0.5
0.5x1000=500
500rpm
If three or more pulleys are used the same calculation can be made.
Example:
second pulley radius=4 inches
third pulley radius=8 inches
motor RPM=1000
2/4=0.5 (first ratio)
0.5x1000=500
second pulley RPM=500
4/8=0.5 (second ratio)
0.5x500=250
third pulley RPM=250
Step 4: Chart
Make a chart of all pulley positions and calculate each RPM.
Step 5: Lathe Speed
The appropriate speed for the wood lathe can be calculated based on the diameter of the turning piece. When you multiply the diameter of the wood in inches by the RPM of the lathe the number should be between 6000 and 9000. I created a graph to help visualize the diameter and speed relationship.
If the diameter is 1 inch the speed should be between 6000rpm and 9000rpm.
6000/1=6000, 9000/1=9000.
If the diameter is 3 inches the speed should be between 2000rpm and 3000rpm.
6000/3=2000, 9000/3=3000.
Heavy roughing cuts should however be made at lower speeds.
Step 6: Drill Speeds
Many drill speed charts can be found online with varying ranges.
Drill speed can depend on:
type of material being drilled
material hardness
hole size
drill bit material
bit sharpness
whether cutting fluid is used or not
etc.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    I think with V belts you need to measure the center of them? Although I'm sure your measurements will give you accurate enough results too.
    Surface speed is calculated with this formula:
    Surface Feet Per Minute = (PI * DIA * RPM) / 12
    DIA is in inches. I'm not sure what you're going on about with how you're figuring things out. With wood values are not terribly critical though.
    Hi, nice Instructable. Thanks for posting.
    The readers may find an online calculator that I scripted with php helpful. It uses AC motor information, sheave diameters and drive wheel diameter to determine the speed of a grinding belt.
    http://dcknives.com/public/belt_speed.php
    DC
    Cool, thanks for the post.
    Thanks, this information will be very useful.
    Thanks for sharing!
