Introduction: Calculating Power (Interactive!)
PLAY VIDEO
Watch the video to learn more about how to calculate power in a circuit using a simple equation to work out the power consumed in Watts. Apply it to any device or circuit.
Try this Circuit!:
To see more from me, subscribe to Simply Electronics on YouTube.
Follow on Twitter
Like on FaceBook
ThomasK19 (author)2016-06-24
P=IV? P=IU!
Sutty5 (author)ThomasK192016-06-24
I'm not sure what your question is here?
ThomasK19 (author)Sutty52016-06-24
The video shows the formula P=IV. This is wrong. I is the symbol for current, and A (Ampere) is the unit. V (Volt) is the unit of voltage but the symbol for voltage is U. P is the symbol for power and its unit is W (Watt) or VA (Volt Ampere). So you either need to write P=UI or 1W = 1V*1A.
I understand that many europeans use U as the symbol for voltage. But most use the SI Unit; V. The aim of my videos is to keep it simple, and explaining the differences between symbols can cause confusion. Perhaps a separate video for this in the future. All-in-all, the calculation works the same whether you use a U or V to represent voltage. P=UI is the same as P=IV. I think it's unfair to state that it's wrong, It's just a matter of preference and how you were taught.
I was not aware of the SI system (probably like most US people are not aware of a metric system). But then this system states the symbol for current is A and for wattage its W (always the same as the unit: http://www.alcyone.com/max/reference/physics/units.html and https://en.wikipedia.org/wiki/International_System_of_Units). So if you reference the SI system you would need to specify W = VA.
Again, this is a matter of where you were taught and your preferences.
This is the SI Notation system I was taught: http://physics-help.info/physicsguide/appendices/si_units.shtml
If you prefer to use those symbols, I have no issues with that. But as I said, it's not really acceptable to state that either method is wrong given that there are many acceptable variations of notation.
Well, that now makes the confusion perfect. A system where you can choose amongst a variety of symbols to denote a physical size? The site you reference is simply wrong. You need to cite NIST in that place: http://physics.nist.gov/cuu/pdf/sp811.pdf and they use W for wattage.
About This Instructable
290views
10favorites
Bio: Simply Electronics YouTube is a channel created to Inspire, Educate and Entertain new and experienced Electronics Enthusiasts. Join me in the exploration of the world ... More »
More by Sutty5:What Is Ground? - SimplyElectronicsHow to Make a Rectifier (AC to DC)What Is PWM?
Add instructable to:
