There is a large variety in commercial pro-styles. This design was made from some steel and wood that was laying around. This dolly holds a tripod. It has 12 wheels (from inline skates) and runs on 3/4" schedule 20 PVC pipe.
This photo shows the dolly in use - without the top. We pulled some slats from a bed to create a more even surface for the PVC to lay on. Also, grass getting into the wheels is a mess and causes vibration. Also seen in the picture are additional weights - in the form of rail road ties. Two 2.5 gallon water bottles should work just as well (at 7 pounds a gallon that's 35 pounds).
Although there are a number of areas that could be improved on the result is more than adequate for high-school use.
Remove these ads by
Signing UpStep 1Materials
qty 2 ) 24" x 2" angle 1/8" angle iron (cold rolled)
qty 3) 30" x 1.5" steel straps (1/8" thick)
qty 1) 4x4 piece of 1/2" ply
qty 12) inline roller wheel
qty 12) 3/8" NC bolt, spacers, nuts
qty 4) 3/8" NC bolts to hold deck (i tried standard, over-sized, nylox, and jam nuts).
*) wood sealant - rattle can
*) blue lock tight
*) black spray paint (with rust inhibitor) for frame
Additionally, Alienjones comment is really relevant about bumps. Try that idea.
Go on making it a bit better. It worths the effort. You'll have a true professional tool.
(Next time don't forget to rotate your photos. :D )
A smoother ride was found by screwing the pipe to the sleepers. Drill a larger hole on top so the screw head can fit through it. The wheels don't feel anything and the whole length is a smooth shoot.
THe trade off benefit of doing this is when you transport it, you only need slide the rails in opposite directions and the rails & sleepers narrow down to a transportable affair you can put on a roof rack or show ski bars.
with 12 wheels it would probably smooth things out. should be able to get the joint within 1/64" -
an automatic cutter
