Wireless\Wired Led Light Panel Camera Light, or Just a Designer Decoration Lamp
Published
Introduction: Wireless\Wired Led Light Panel Camera Light, or Just a Designer Decoration Lamp
About: Geek, Crazy, Loner, WannaDuino!!!, A LIVE. And really a crazy professor. DIY, RC, Fun, 3D Printing, Arduino, And much more..........
The full power is not captured by my phone camera but the most of you wil know that it has to do with the settings of the camera.
i am a all round diyèr, many more wil follow ( i will give some upcomings now! )
portable power bench supply with USB charger and Voltage display, ( seen in this video )
Rolling brief suit case car stereo 150Watt 10Amp BOOM Box
Portable Solar charger station
Drone builds
Transmitter Mods for RC`s
the smallest YES the smallest Voltage power supply in MY world with display and variable voltage and current.
And a briefcase changed into a Ground Station for FPV with lipo battery charger-display-FPV gear-...........
Pleace Comment,
Like
Subscribe
Step 1: Camera LED Light, DIY Wireless Also.
MY way of thanking you all and INSTRUCTABLES, Is to do what i learnd from all of you. to put my first (many wil folow i hope ) IBLE. greetings from The Netherlands WannaDuino thats ME!!!
Bare with me that this is REALLY my first INSTRUCTABLE so i need a lot of improvement commends thank you.
Or not, then this wil be the BEST IBLE EVER.
Step 2: The Parts I Used
YESSSSS My First Instructable, (or something like a Instructable )
Because i needed good and extra lightning for my new hobby, making video`s of my diy projects. I made a simple LED light from old parts and a cheap LED strip. The parts i used are from my old Dell computer tower, i used the top for my base where i put the leds on. also to keep it as cheap as possible but also to re use old stuff. Bare with me that this is REALLY my first INSTRUCTABLE so i need a lot of improvement commends thank you. Or not, then this wil be the BEST IBLE EVER.
LED strip 5M ( 3$ )
Base plate ( free ) my old PC
Plexi glass ( 4$ ) not necessary
Camera mountings ( free ) from my camera`s
Needed parts to build
Solder app,
tape
cutter
stripper
Step 3: Cut the Strips and Tape It Stuck.
Its not that hard to make, cut in my case 14 pcs of 25cm strips and lay them all together as i did and tape it.(i placed the strips like snake way,just as from the role of the ledstrip) so it lookes need.Because of the tape on the front it become 1 piece and you can fiddle around with it, without loos them in what way it can bend or shuff.then you take your base,put it on there and look how it will be when its finished.
Step 4:
then you can begin to make al your needed wires (in my case 24 pcs 12 red and 12 black. of 3 cm in my case. and strip them 1.5mm on each end and with them.
Step 5: Always Test During a Build, I Had 3leds on the 22e Row That Were Dead, So Cut It Out and Replace.
and then you can begin to solder i placed my strips in columns so i must solder from strip 1 to strip 3 and so on. and you do that also on the other side but in the opposite direction as you see in my pictures. so firts 1 side then the other. or elso you must by every strip turn your base to solder the next strip. but you can also choose to place the stips al pointed to the same side, but then you have to solder it in a different way. i soldered it like this because al the LED`s are spreaded and are not al in 1 line.And always test it if there are problems before or AFTER. as i had.
Step 6: Finishing It and TEST
Now we can finish it of with a piece of plexi glass icut.
just make some holes with a drill and use some risers to attach them to eachother.
And wholah we have LIGHT.
Step 7: The Camera LED Light in ACTION!!!
Greetings from WannaDuino from Holland
special thanx to al the Members and Makers of this AMAZING platform that made me to the man i now am.
yes sounds sobby, but the last 2 years .....lets put it this way ( i am re born in a good way, a bit to late but i think a few of you wil know exact what i mean )
INSTRUCTABLES hell YEAHHHHHHHHH
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    4 Comments
    Thank you so much, for that compliment.
    but its not that difficult to make dear friend.
    If needed i will gladly help or give pointers.
    WannaDuino
