3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camera Mouth Holder
Camera Mouth Holder
Ever wanted a 3rd hand to take pictures of yourself doing an instructable step ?
Either you don't have 3 hands (like me), nor a tripod (which can be unpractical in some cases). Asking friends for help until you're satisfied with the shot will surely strain their patience.
This mouth handle will allow you to take point-of-view pictures and let your both hands free.
Step 1Build it
Build it
You will need:
- 1 wood stick
- 1 quite short screw fitting your camera tripod fixation point
- some washers
Steps:
- determine the length from the mouth end to the screw. Approx 7 inches.
- drill a hole for the screw
- use washers to adjust the length: the screw should enter into the camera for about 2 turns only
23 comments
Jan 18, 2010. 11:56 PMKryptonite says:
Very nice! I'd have to find a way to trigger it with my tongue though, because my camera doesn't have a timer.
Sep 4, 2009. 5:15 AMLokisgodhi says:
I'd suggest that a piece of polyethylene rod would be more sanitary and last a lot longer.
Jun 16, 2009. 4:40 AMPlasmana says:
Wow, that is very clever!
Jun 15, 2009. 7:57 PMl8nite says:
great idea but my jaw hurts just thinking about it!
Jun 14, 2009. 1:48 PMlemonie says:
Fantastic. Like holding solder in your teeth, except I tend to drool on it... L
Jun 14, 2009. 10:47 PMaxist47 says:
Have you ever burned yourself?
Jun 14, 2009. 11:33 PMlemonie says:
A few times years ago, but not by holding things in my teeth. L
Jun 15, 2009. 7:21 AMmattthegamer463 says:
lead-free solder I hope? :)
Jun 15, 2009. 10:53 AMlemonie says:
No, but I leave it in the container. L
Jun 15, 2009. 4:29 AMsiklosi says:
What about holding with your mouth Nikon D3 with Sigma 50-500 :)
Jun 14, 2009. 9:18 PMKeeter says:
I would suggest the same as caitlinsdad said, and use something that goes around your neck, like the harmonica holders. And taking a picture of both your hands is cool, but the fact that you took a picture of yourself, while taking a picture of yourself, now that's impressive :P
Jun 14, 2009. 7:01 PMluvit says:
don't run around the house with that in your mouth or i'll take it away from you.
Jun 14, 2009. 6:57 PMpuffyfluff says:
This is a great idea. An external shutter button would be helpful, though. As Kanein Encanto suggested below, a modified tongue trigger may be helpful, and with that, it may be helpful to use jaysbob's idea of the wider an thinner board.
I'll have to make one of these one day...
Jun 14, 2009. 6:51 PMjaysbob says:
great idea! a wider thinner piece of wood seems like it might be more comfortable to chomp on. At least so you can utilize your wider flatter molars in back to provide a more stable and even clamping force than just your thin front teeth. depending on how heavy your camera is this could also negate the need for a chest stabilizer. May also be a good idea to make sure your using untreated wood, reduces the chance of getting some kind of weird chemical poisoning. probably doesn't matter either way though. sounds like this was just made with materials on hand though, and for that its an awesome proof of concept!
Jun 14, 2009. 5:43 PMHawkins8692 says:
Brilliant!
Jun 14, 2009. 3:49 PMKanein Encanto says:
Something to check: If the camera can have a cable release switch attached, find a way to secure it so maybe you can press on a modified cable release switch with your tongue or if it's a tougher switch, additional pressure from clenching your jaw...if you can do that... maybe it would be a little easier to use than holding the rig for ten seconds.... not to mention re-taking a shot would be easier maybe too. :)
Jun 14, 2009. 2:10 PMmaxstevenson says:
Great idea! Thanks. I will use this.
Jun 14, 2009. 11:36 AMWeissensteinburg says:
I would change your intro picture to one of the final product, it makes it easier to understand what the project is from the index.
Jun 14, 2009. 1:05 PMWeissensteinburg says:
Perfect! I'd make one of these, but my camera is too heavy =[
Jun 14, 2009. 10:25 AMjessyratfink says:
This is sort of amazing. I mean, you look silly doing it, but it's really useful! :D
Jun 14, 2009. 11:16 AMcaitlinsdad says:
Might be easier if you mod one of those chest harmonica holders that they use while also playing guitar. Many are made from just coat hanger wire/duct tape and relieves the stress put on teeth/braces. Maybe you should get a sports mouthguard to attach for a true orthodonic device.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
222
Author:laxap
I like things that are cool, useful, efficient and well executed. At best, all that in the same time. Subscribe to me! If I inspired you, share it: post photos in a comment, and you'll get a patch. ...
more »
