Camera Panorama robot head (panograph)
Ever wanted to take pictures of a panoramic scene at the press of a single button? This instructable will teach you how to build a robotic head to mount your camera on, which in turn mounts on a tripod. The robotic head will move in two axes to enable the camera to be panned left and right as well as up and down
There are a few pre-requisites:
I've used a Canon camera which is loaded with CHDK alternative firmware. *check comment on this later on. Visit http://chdk.wikia.com/wiki/CHDK to check your camera compatability.
A little soldering is involved as well as some practical mechanical skills
This is released under Creative CommonsAttribution-Share alike 3.0 license http://creativecommons.org/licenses/by-sa/3.0/
Step 1Build Steps
Build Steps
Here I've added an index which I hope will make things easier for you.
1 Upper Rig assembly
2 Gear bearing assembly
3 Servo PCB wiring & fixing
3 Picaxe programming
4 Final assembly
5 Load CHDK on your camera
6 Calibration
7 Example panoramas shot in location in North Wales
20 comments
Mar 16, 2010. 3:12 PMnix78 says:
 That's not a stepper motor, that's a servo, I believe.
Mar 31, 2011. 10:28 PMVadimS says:
You would be correct.
Jan 17, 2011. 11:59 PMshmootz says:
Thanks for the instructable. Just wondering, does this need to be done with a Canon? I have a Nikon d40x which I would like to use with this... Thanks.
Mar 16, 2010. 4:53 PMnix78 says:
It is also worth noting that on should adjust the position of the camera in the "upper rig" (or tilt frame) so that the nodal point of the camera is as near as possible to the intersection of the horizontal and vertical rotational axises. This way, one could minimize the parallax error.
The gear ratios could be simply 1:1 for the horizontal axis and 2:1 for the vertical, because most servos can do +-90 degrees rotation, and the torque should be enough to hold a compact digital cam (not DSLRs, of course).
(Pardon my English, it's only my second language, and I'm also a bit excited, because I just won an auction for a camera for a similar project of mine. :) )
Sep 19, 2009. 7:11 AMboobathi2008 says:
i need some information about robotic method of work this information help for impliment in human body ok
Aug 21, 2009. 7:01 AMMaggy160 says:
Waldy has had a discusion on http://www.picaxeforum.co.uk/showthread.php?t=12754 about material and software improvements. Waldy, it would be very much appreciated by those who want to build this panobot if you could give us an update about the code you're using now as well as pehaps other choice of servo's?
Jun 24, 2009. 4:02 PMjaredarm says:
That is too weird! I recently got into panoramas and the whole 300 degree stereographics and little planets. And then i was also recently introduced to Max/Msp/Jitter and I thought, hey wouldn't it be cool to build an automatic panorama shooter.... HAHA! I really wanna build this now!
Jun 15, 2009. 8:19 PMpitty says:
Great Instructable, I think I am going to build one with a few modifications for my camera. Would you be able to provide a longer description of what each of the symbol commands in the program represent in relation to the position of the rig, and the what the 2 delays are for. Thanks
Jun 22, 2009. 9:51 AMthepelton says:
Delays would make it possible for a person to set up the panorama camera, and then sit down in the picture area. Here I am at the Grand Canyon!
Jun 22, 2009. 1:10 AMlucastro says:
I've just recently discovered the wonders possible with CHDK.. I was making a timelapse the other night and thought it would be awesome to have a device just like this, only to achieve a pseudo 'handheld' camera effect. was thinking maybe film a short piece, motion track it somehow, slow it down accordingly during the time lapse. Nice Instructable.. could you control the mount via the camera usb.. ie write the control parameters into the script? oo the motion tracking possibilities! Sorry you've got me all excited.
Jun 22, 2009. 1:44 AMshadowman2 says:
The G9 rulez (i have it)
Jun 19, 2009. 10:30 AMjoejoerowley says:
Very Cool!
Jun 18, 2009. 11:55 PMpitty says:
Thanks Waldy I have started ordering my bits to make one of these. I will have to adapt it a bit as I am using an SLR, but I know I can make it work.
Jun 16, 2009. 8:07 AMjj37 says:
I always wanted on of these and by the way nice pics. 4.5 stars and a big THANKS
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:waldy
