3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camera Panorama robot head (panograph)
Step 2Shopping List
Shopping List
1x Brookes basic tilt frame for KAP http://www.kapshop.com/product_info.php?cPath=6_26_42&products_id=159 9 pounds 50p
1x Brookes better gear guide http://www.kapshop.com/product_info.php?cPath=6_26_42&products_id=75 8 pounds
camera bush screw http://www.kapshop.com/product_info.php?products_id=231 2 pond
2X servo motors http://www.mutr.co.uk/product_info.php?cPath=13_530&products_id=1009437 3 pounds each (You'll need an extra one if your not firing the shutter with CHDK)
1x picaxe servo board (AXE024) http://194.201.138.187/epages/Store.storefront/?ObjectPath=/Shops/Store.TechSupplies/Products/AXE024 7 pounds 50p
2x Gear sets http://194.201.138.187/epages/Store.storefront/?ObjectPath=/Shops/Store.TechSupplies/Products/GWC031 one pound each
22mm aluminium cylinder cut to 50mm length (can be much shorter depending on your tripod head clearence) http://cgi.ebay.co.uk/ALUMINIUM-ROUND-BAR-ROD-5-8-DIA-x-250mm-Long_W0QQitemZ270282531024QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET?hash=item3eee1820d0&_trksid=p4634.c0.m14.l1262&_trkparms=|301:0|293:1|294:30
1 four cell AA battery holder + PP3 battery clip
various nuts, bots & split washers
tie clips
1x toggle switch
for noise supression
4x clip on ferrite noise supressors
4x 100nF ceramic capacitors
tools
dremmel type drill with attachments
1/4-20 tap for attaching rig to tripod
M4 tap for attaching rig to tripod mount cylinder
soldering iron
multimeter
Cable for programming the picaxe http://194.201.138.187/epages/Store.storefront/?ObjectPath=/Shops/Store.TechSupplies/Categories/SoftwareCables/CablesAdapters 3 pound (you will need a serial to usb adapter also if your pc does not have a serial port
vertical drill stand, or access to a workshop to drill holes in aluminium rod ready for tapping
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:waldy
