Step 51 Upper Rig build pt 3
Attach a 4mm diam. threaded rod to the left hand side of the outer cradle as shown in the picture. ( I used a long nut & cut the head off)
Position the rod into the inner cradle using one of the pre-drilled holes so that the distance between the rod centre and the inner cradle base is about 20cm. Use one of self tapping screws that came with your servo accessory kit to screw the other arm of the inner cradle to the servo arm centre hole. Check before screwing that the iner cradle base runs parallel to the outer cradle base.
Add Comment
