loading
Step 3: The Camera Mounting Platform
The next step is to determine where to put the camera mounting platform. Ideally you want to get the camera centre of gravity over the middle of the "T mount", but you don't want any of the "T mount" appearing in the shot when the camera is in it's widest view setting.
I made my camera mounting platform from a stack of 3 X 80 mm long pieces of 40 mm x 3 mm aluminium strip; I needed about 9mm to allow the sun shield on my FZ50 to clear the T. You will have to design your platform to suit your camera with the attachments you intend to use. If your camera mounting hole is off-centre you may have to do some design adaption. There is nothing preventing you from drilling the T to allow more than one camera position or even another camera (T for 2 i{^_^}).
If possible it is a really good idea to avoid covering the camera battery access with the platform; I can actually change the batteries on my camera without disturbing the camera alignment.
Examine the photographs to get an idea about the platform and how it works.
I used 2 x 3/16" 38mm long countersunk screws to hold the platform in position. At first I used ordinary nuts but later I changed to dome nuts to avoid things catching on the screw ends.You will also have to drill a 1/4" hole right through for the camera mounting screw.
I put tape on the platform to give a better grip and some protection to the camera. The first tape I tried was a special soft vinyl tape but it did not stick well; I later changed it to the tried and true book binding tape.
Show!
Cool build, I'm designing something similar, hopefully building it sometime next month. My one concern on your setup is that it could get knocked over if the camera or tripod is jostled (the cupping being rather shallow). I'm toying with a clamping system, as safety wire still wouldn't help much with toppling.
Actually the camera and T mount are only on the base for the short time while I am taking a shot. I keep the strap around my neck the whole time and most of the time the camera, and attached T mount, are resting comfortably and safely on my tummy. In this position the T mount actually makes it easier to access the camera menu and change settings, the mount keeps the camera orientated while buttons are pressed.<br> The only time I have a worry about sliding is if I am taking pictures at a steep angle, greater than ~15 degrees. Even then the camera is in no danger, it just means I cannot use the OB-Pod to get that shot.<br> I am working on improvements that will solve this problem and also make the design more stable (OB-Pod Mark II ?). In fact the last few of the parts I need arrived a couple of nights ago from China.<br> Keep in mind that any clamping system has to be able to be activated and deactivated with no force or vibration. I evaluated about 5 different systems before I came up with what I am using in Mark II.<br> I hope to have it up soon so perhaps you can take advantage of the new design.<br>
Nice photos ;) Very well made ible :D
About This Instructable
11,564views
35favorites
License:
More by Light_Lab:Hooked on Tablets Send your family (or someone elses) To Hal...loween Camera Support For all Multi Shot Photography - The OB-Pod
Add instructable to:
