iImage Information
I have seen many camera tazers, but none on this website that are illustrated all the way step-by-step.All you need is an old disposable camera, prefferreably Kodak. All brands work, but all are different. I found kodak the easiest type to make a tazer out of.
So, i am posting mine. It comes from a Kodak Powerflash, and can give 380 volts. i hope you enjoy
Step 1Opening the camera
iImage Information
first, peel of the stickers to reveil the tab things you are supposed pop open.
using a flathead screwdriver, pop open the tabs.
plastic is a resistor = doesn't conduct
You measure the amps something is pulling by putting your multimeter in series with the load.
You cannot ''give'' too many amps, you can only "pull" them.
Say you have a motor that pulls 1000mAh(motor current varies a lot, but lets say it is a constant), if you wire it to a 4000mAh battery, it will ONLY pull what it needs to operate which would be 1000mAh
