Camera Tube Dolly: Step by Step
 by Almost Midnight
Featured
We chose this design for its easy to find materials and practical transport possibilities. Moreover, many dollies need you to find a tripod head, for which we didn’t have the budget.
Step 1: Materials
Total for a Vinten ProTouch 3809-8 tripod with a track of 6m, check below for details on how to adjust the tubes to your tripod and track distance.
• 18m x 50mm diameter hard PVC tubes
• 2 x T-section tubes, 50mm diameter
• 8 wheels, ideally rollerblade wheels with screws, bolts and washers
• 3m of plywood
• Some sort of shock absorbing material: foam, yoga mats or springs.
Optional (for dolly track rails)
• 6m of plywood
• 2m of 2x4 wood
Tools
• Saw
• Drill
• Strong glue
Tip: Ask your local hardware or furniture store for their wood leftovers.
rimar2000 says: Oct 2, 2012. 4:59 AM
Mine was just a suggestion, I am not a photographer. Why you think you should raise the camera position by replacing the wheels by those little carts?
Almost Midnight (author) in reply to rimar2000Oct 2, 2012. 5:23 AM
Thank you for the suggestion - I always like to improve.
At the moment the wheels are drilled on the sides of the dolly cart tube itself, with only a minimal distance between the track and the cart. I believe the parts you suggested would place the wheels in between / under the cart, creating a space of a few cm's between the cart and the track.
There's two reasons that in our movie project we like to keep the distance between the tracks and the cart to an absolute minimal. Firstly, safety is crucial. With more contact surface between the track and the cart, we might have less chances at accidents. We're using this dolly for action packed scenes on the street, so at times it gets rough.
Secondly, at times we like to make shots very close to the ground, in frog perspective. Often a cm or two does a lot to a take.
Considering our budget, we were also forced to opt for the cheapest solution.
For other photographers these spare parts would be an awesome solution: my guess is that they're easier in assembly and more solidly built than our wheels.
rimar2000 in reply to Almost MidnightOct 3, 2012. 6:21 AM
Yes, now I understand. "Never missing an Eskimo willing to teach an African to combat a heat wave", forgive me.
DconBlueZ says: Oct 2, 2012. 9:59 AM
Very detailed Instructable, I know someone who might use this, thanks!
Almost Midnight (author) in reply to DconBlueZOct 2, 2012. 3:55 PM
Thank you! I'm very interested to hear if they're as happy with this design as we are.
rimar2000 says: Sep 30, 2012. 6:09 PM
Very interesting design. Maybe these spare parts could serve to make the wheels more easily. I don't know how to name them.
Skrae86 in reply to rimar2000Oct 2, 2012. 5:56 AM
These wheels look like the runners used in common internal cavity slider doors. They're generally only 30mm wheels but if you could find a larger version they'd work great!
Almost Midnight (author) in reply to rimar2000Oct 1, 2012. 7:43 AM
Thanks! With some more budget, they would definately make the assembly easier. I'm not sure what they're called in English either.
A concern could be that you would loose contact surface between the dolly cart and the dolly track. I used this dolly for some shots of a man running through the street, and in order to follow him the cameraman had to run the cart over the track at equal speed. I'm afraid that if I put the cart higher up, and consequently the tripod and the camera as well, I might loose on safety.
If you try it out though, I would be very interested in hearing how it wen
rimar2000 in reply to Almost MidnightOct 2, 2012. 4:59 AM
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
