3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camera Zip-lock
Camera Zip-lock
You've got a snazzy digital camera, but you want to take it into a wet, dusty environment. Protect it with a simple zip-lock bag and a filter.
Step 1Gather Materials
Gather Materials
You'll need:
- Zipper lock bag: 1 Gallon size is fine for a DSLR and a medium zoom lens.
- Filter to fit your lens: You probably want a transparent "Skylight" or "UV" filter. I got cheap ones for this project because I expect them to take some abuse.
- Sealing tape: I used electrical tape, but duct tape might provide a superior seal. The tape will only touch the bag and the outer ring of your filter, so if it leaves gunk behind, it's no big deal.
Tools:
- Marking implement: Fine-tip sharpies write well on plastic bags.
- Cutting implement: A small pair of scissors works well.
56 comments
1-40 of 56next »
Jul 30, 2010. 7:33 AMcory.smith says:
I wish I had thought of this before heading off into a local cave for some pictures. =/ Instructable for underground photography is in the works....=D
Apr 22, 2010. 12:41 PMjamoskirk says:
If you had a Pentax DSLR you wouldn`t need to protect it from water or dirt =)
Sep 22, 2009. 9:28 PMjameslkieb says:
Well done. I also did something quite similar to keep my "one and only" safe at Burning Man. I cut the corner out of a bag and used a big, thick, blue elastic that is commonly used to hold broccoli stalks together. A UV filter protected the front surface of my lens and gave me more contact point for the elastic. I I left tabs around my hole cutting and folded them back over the elastic and used a second one to secure it. This stayed on without adjustment for a whole week. I positioned the other bottom corner of the bag near the scroll wheel of my 1000D. Accessing features was very easy. The "sip" of the bag fit at the bottom to stay out of the way. I screwed my trooped mount through bottom of the bag with an extra piece of rubber on the inside to keep the seal. The only problems I had were trying to manual focus at night through the obstructed view finder and having my auto focus bind up a bit with the twisting of the bag. I used a fairly heavy grade of bag. A little pre shot adjustment was all that was needed. Cheap, easy and completely non destructive. Not one speck of dust got on my camera.
Jul 28, 2009. 11:27 PMJaysn says:
You could make a more secure seal with one of those vacuum sealing machines they actually melt the bag closed. Just a though.
Apr 12, 2009. 7:45 PMtriggersnappy says:
WHOA!!!! call me old fashion or a sucker for the pro gear but there is no WAY i am whacking my 5D Mark II and an L lens in a ziplock bag taking it for a dive! in the rain maybe ... and a coupla of hundred dollars point and shoot perhaps but a DSLR!??
Mar 4, 2009. 1:45 PMThelonelysandwitch says:
I do this all the time with my cell phone, just with special bags.
Aug 12, 2008. 10:52 AMShaeren says:
Hey,
any thoughts on the Aquapac SLR case?
http://www.aquapac.net/usstore/erol.html#588X1411
Jul 28, 2008. 9:07 PMknoj says:
I have been using this method for a while with great results. I trust it with splashes and dust, but I don't trust it under water. The auto-focus doesn't turn the bag much, just leave some extra room for the bag to twist a small amount. I took the picture below just yesterday. Good luck!
Jul 29, 2008. 5:16 AMknoj says:
Yeah water balloons, nothing special, just put the camera on continuous shoot. I shot about 200 shots making sure to get as many frames as possible. Pick a sunny day so you can speed the shutter up. Don't be afraid to get close. We're definitely doing this again, it was fun for everyone.
Dec 10, 2007. 1:21 PMbaliboards says:
No more worries for dust, grim, splash or swimming. No need for zip lock. Of course, you gotta pay out a bit, but it's worry free. We were using the ziplock solution here in Bali a while back. We'd sign onto American sites <a rel="nofollow" href="http://www.gtzip.com">Zip</a> and get samples of little size bags delivered to us in Hawaii. This was OK for the flat digi cameras in mild surf. But no need anymore - good waterproof cameras are selling for 130 Euros. Mine is Pentax. It gets pounded - still works fine. And it's over a year old, so new ones must be better. Forget the big SLR's, that's for the pros. Check out <a rel="nofollow" href="http://www.surfingmagazine.com">SurfMag</a>. You can't compete with that; better stick to snapshots. And use the ziplocks for clothes and stuff.<br/>
Dec 15, 2007. 11:53 PMbaliboards says:
You're spot on. I'm with you all the way. And I like the intensity. I was thinking - 130 Euros is no big deal for me, rich Aussie in Bali, but it's 8 months wages for the typical villager. Older cameras tend to be shared amongst relatives and friends. What are they to do when taking pictures of religious ceremonies on the bay or parades in the rain? Simple solution - put their camera in a zip lock. Which brings us back to your original idea.
Nov 28, 2007. 8:07 AMRibs says:
Instead of usind desicant packs just hold the zip-lock in front of an air conditioner for a few mins, this shold make the air dry and solve the vapoure problem.
Oct 11, 2007. 9:17 PMdolpolens says:
I can't belive you guys are risking expensive equipment in these cheap bags. I spoke with my friends at www.gtzip.com and www.minigrip.com (they own the patent on ziplock bags) and both companies stress that neither the seal nor the material (polyethylene) is waterproof. Furthermore, internal condensation is possible. Maybe www.gore-tex.com has a solution. In the meantime, be careful.
Nov 28, 2007. 7:58 AMRibs says:
i went to the goretex website and couldnt find anything to do with cameras where should i look?
Nov 18, 2007. 7:18 PMTheMadScientist says:
the guys at gore tex tend to be quite gay about their material. I wouldn't count on it, seeing as by gay, I mean they don't sell to anyone besides "qualified gore-tex distributors". yeah, they can suck it. Me? I use the water sealed 50 cal ammo boxes with a bit of piping, a camera lense, and two O ring rubber seals. if you need to go underwater, use counterweights. but yeah, goretex dosn't sell to individuals. it says so right on the website.
Nov 18, 2007. 8:55 PMdolpolens says:
I guess that Gore-Tex needs to protect the reputation of their product. Maybe their own R & D department can work on a clear waterproof membrane. Of course, your idea sounds like, and has proven to be, the safest solution. But I'm still intrigued by the idea of a super lightweight malleable wrap that can protect the camera underwater. I see that they now make ziplock bags from an ultra clear plastic (the kind used for notecards) and that it is less permeable than the household variety foodbag. A Google search finds www.gtzip.com and buyplasticbagsdirect.com among others that sell these new bags. In theory, the pictures should turn out a lot clearer. Someone else can risk their camera then get back to me. Good luck!
Oct 27, 2006. 10:35 AMk3nt says:
thanks for posting this. i live in vancouver canada and have been itching to get out and photograph in the rain. there's a red colored construction tape available in hardware stores that bonds very well to plastic.
Oct 27, 2007. 4:47 PMwikityler says:
Tuck tape. It's well suited for this purpose, because it is intended to seal vapour barrier.
Sep 11, 2007. 3:58 PMMarilik says:
Awesome... here's my photo
Sep 11, 2007. 10:45 PMMarilik says:
Actually aneel, i did! I Wrapped the camera in plastic wrap before putting it in to the Ziplock Bag. But to tell you the truth, i don't see it being very necessary. I did however try to suck most of the air out. This was just to have the camera nicely positioned inside. I also Taped the ziplock opening closed with Electrician's Tape. THANK YOU VERY MUCH!!! You've opened up a new form of photography in my world!
Aug 19, 2007. 3:11 PMje1330 says:
aneel, I made one of these for my Olympus e500, thanks so much for the idea! A friend was having her little girl's first birthday party at a city park with a lot of water features. I never would have gotten close enough for this picture without the ziplock enclosure. For anyone trying this out, as has been said before, it's certainly not water proof, but it is completely splash proof. The two things you have to worry about are droplets on the filter, which you'll be able to see through the view finder, and fog on the lens. When looking through the bag into the viewfinder, everything looks foggy anyway, so remember to keep checking the front often. Next time, I'm going to take some wetnaps or something like them, your shirt just doesn't work once you get wet too. haha -- jason
Aug 19, 2007. 3:12 PMje1330 says:
Here's the image, hopefully, it didn't attach before...
Aug 30, 2005. 3:05 PMbryankennedy says:
i am a little confused. wouldn't this get a twisted up as soon as you need to focus the camera? or once the auto-focus kicks in? maybe i am just missing one of the steps.
Jul 28, 2007. 9:14 AMELF says:
Depends on the lens. The standard 18-70mm for the D70 got internal focus and even though it will be tough to turn the zoom ring, the front wouldn't twist, so you wouldn't twist the bag... :)
Sep 24, 2009. 8:42 PMdolpolens says:
I see where they are making padded ziplock bags now (Bubble Zip). This site has some: www.gtzip.com Cheap, but the minimum seems to be 100 bags. Also, I would prefer they use the slide zipper rather than the traditional ziplock closure. Anyone find some?
Jul 10, 2007. 12:39 PMcprogrammer says:
You could put silicone sealant around the gap. These sealants can be found in any aquarium shop (The are used for sealing aquariums).
Mar 31, 2007. 9:47 AMpower says:
can it be putted into the water? just to make sure
Apr 25, 2007. 3:44 PMmarc92 says:
You could just buy a disposable, waterproof camera at your local drug store.
Apr 19, 2007. 3:00 AMthe fat hobbit says:
great idea my ish is always getting dirty and its a bitch to clean though a zip lock would make changing settings hard wouldn't it??
Feb 26, 2007. 7:36 PMl8ntpianist says:
i knew a couple of fellows in the navy that were into diving and snorkling. they would use a disposable cam and a ziploc. the pics were beautiful.
Jan 14, 2007. 5:50 PMbuildingteen says:
for the dessicant packs couldn't you use kno3 and tape it inside of an old hand warmer pack? and i made one that attaches to a graduated filter the ring stays centered but the piece with the slots stays stationary because my 75-300 has external focus and also my bag is made of shower curtain liner and since my friend made a heat sealer for a diferent project i was able to seal it water tight and the back is zipper heat sealed on with two water tight zippers so it works great for like shallow water pictures! and is that a D-70/D-70s?
Oct 26, 2006. 6:44 PMCanDo says:
How about creating/reinforcing the seal by using bicycle innertube instead of/in conjuntion with tape?
May 18, 2006. 8:43 PMdll932 says:
Warning! Beware of moisture condensation in the bag-it should be vented from time to time, or the inside of the camera will rust.
May 31, 2006. 9:28 PMMyself says:
Easy enough to toss a few desiccant packs in there. Reactivate them first: Any desiccant pack that's been sitting around the house for a few weeks should be considered "full", as it's probably absorbed as much water as it can. Using a milligram balance, record the mass of each pack beforehand. Throw all your desiccant packs on a cookie sheet and bake them overnight in an electric oven at 200 degrees or so. The flame of a gas oven produces moisture making it unsuitable for the task. (Solar ovens would be ideal!) Compare the mass afterward to get an idea of which packs had the most to lose, which (assuming they were all sitting in the same moist house air beforehand) tells you which ones grabbed the most out of the ambient air. Throw an aggressive one in your baggie with the camera.
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:aneel
