3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camera for time lapse pictures made easy.
I was checking out one of the other Instructables about making time lapse movies. He pretty well covered the movie part. He told about the free software that you could download to make the movies. I said to myself, I think that I will see if I can make my camera into a time lapse camera. I have wanted to do the time lapse thing. First I had to think about all the good junk that I have lying around. I remembered the video camera that I took apart. It had some nice parts in it. One thing that I needed from it at this time was one of the motors that ran the lens. I got out the motor and checked it with a 9 volt battery. It worked really nice. With the gear reduction that it had, I thought it would be just what I needed. After checking that out, I had to do a little thinking. I just got out all my tools and went at it. I am hoping that you will be able to see the test run that I made after I got it put together. It is the first picture.
Here is a link to the video that I have on YouTube; http://www.youtube.com/watch?v=C6-Kz_LSUlA
Note: (You will need the Firefox browser to view the site. IE will not let you open the pictures right or make comments on what you see. Thanks for viewing the site.)
A word of two on safety; anytime you are working with any kinds of metal, you need safety glasses and other safety type equipment. Gloves are also helpful. I can not be responsible for any harm that might come to you if you try to build this instructable for yourself.
Step 1Parts list and equipment used.
1. Drill and bits.
2. Grinder
3 Files
4. Saws
5. Safety glasses.
6. Gloves.
7. Metal cutters
8. Pliers
9. Needle nose pliers
10. Vice gripes
11. Hammer
12. Small screw driver set.
13. Regular screw driver
Material
1. Small motor
2. Battery 9 volt.
3. Small pieces of tin
4. A few screws.
5. Duct tape.
6. Pill bottle
7. Camera
13 comments
Dec 31, 2008. 7:47 PMMark Rehorst says:
This is a great idea but doesn't allow much control of the timing of the focus and shutter. I am working on a design for a programmable intervalometer that uses a uC to time the focus and shutter closures. I was going to use relays but that would require modification to most cameras. Your method of mechanically tripping the shutter is a much better way to go. An RC servo could stop at the focus position for a few seconds, then continue to trip the shutter. Another way would be to use two solenoids at different positions on the lever arm- one far from the shutter button would pull the lever down far enough to set the focus and the other, located close to the button, would pull the lever far enough to actually trip the shutter. Or use a motor to drive a screw that operates the shutter button. A few revs activates the focus and a few more trips the shutter. Drive it in reverse to release the shutter.
Jan 1, 2009. 10:52 AMMark Rehorst says:
How do you control the interval between pictures? What is the range of that control?
Jan 1, 2009. 5:17 PMMark Rehorst says:
I was not able to get the video in this instructable to play but the youtube video worked. I don't know about your specific camera, but many digital cameras can't record pictures as fast as you're running. Many also require as many as a few seconds just to focus. I think a lot of time lapse situations (clouds, flowers blooming, etc.) would require longer intervals than you can achieve by playing with the voltage to your motor. As you drop the voltage the torque drops and when the voltage is too low the motor won't have enough oomph to push the shutter button.
Dec 30, 2008. 8:20 PMAshemha says:
Great Instructable. I have a "slow" timer motor out of an old outdoor mechanical timer. This should work great for a steady rotating mechanism. Did I miss the link to your images?
Dec 31, 2008. 10:16 AMTrebawa says:
If you have a Canon PowerShot, there's this great little thing called CHDK that adds a whole bunch of features, including intervalometers.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:cateddy
Retired and live in a little trailer park. I have a bunch of computers networked together that I mess with. We go to the gym. Spend a lot of time going between here and the hospital for different prob...
more »
