Camera-microscope adapter for less than $15
 by 5inister
Make a microscope adapter for SLR and DSLR cameras and learn how to get proper exposure while using it.
Step 1: Materials
You will need the following materials, most of them are fairly cheap and can be bought on-line or at any hardware store, I made this for any Nikon camera but the list is universal:
Camera Body Cap (Available at ebay for Nikon and Canon).
PVC pipe slightly smaller in diameter than the body cap (I used 5cm / 2" for nikon cameras).
Sheet of foam (Ethylene-vinyl acetate) 5mm / 1/10" thick.
Mate black spray paint.
Crazy glue or any other cyanoacrylate based glue.
A ruler, a drill, circular saws, scissors, hot wire and other cutting/measuring instruments.
Step 2: Cut PVC pipe and spray paint.
Cut the PVC pipe, I cut it to a length of 5cm / 2" but the length is up to you.
Keep in mind that the longer the PVC pipe the more magnification you get from the microscope. Pipes longer than 10cm / 4" will require exposure times grater than 4 seconds (under ISO 200).
After you've cut the pipe make sure the base and the top are straight by sanding the edges. Once you have a pipe that will stand straight on a flat surface you can start painting it.
Remember to use mate paint, otherwise the glossy finish will cause reflections that will show in your photos. While painting apply several thin layers of spray paint.
Step 3: Cut and glue foam.
Cut (using hot wire) the foam to make a ring (like the one on the photo). The outside of the ring should be of the same diameter as the PVC pipe, the inside of the ring should be slightly (about 0.5cm / 1/5") smaller than the eye piece of the microscope that you will use (so you need to measure the eye pieces before you start).
Once you've got your ring, apply a small amount of crazy glue to one edge of the PVC pipe and glue it to the foam while applying pressure.
Step 6: Taking photographs
To take pictures you must use the lens of the microscope.
LIGHTING
I always use Kohler ilumination for light microscopy, you must start by doing this even if you want to do dark field or phase contrast photos.
FOCUS
Focus should be made looking through the camera, it may be a little hard to focus since the texture on the focusing screen becomes very visible.
EXPOSURE
If you are using a film camera make sure the light meter works without a lens, if it doesn't try ISO 400 for 1/2" second with the lamp brightness of the microscope set to the highest possible.
If you are using a digital camera the light meter probably won't work with this adapter so the best shot is to make a first exposure using ISO 200 and 1". Then on the picture preview check the histogram (levels). If the levels are to the left than increase exposure time, if they are to the right than decrease them. The idea is to have as much as possible of the area with bars (see picture).
WHITE BALANCE
White balance must be set to "Tungsten Light" or "Auto". For film cameras a blue filter (80B @ Amazon.com or Ebay.com) must be placed on top of the microscope lamp.
SHOOT THE PICTURE
When you are ready to shoot make sure you do so by using the self timer or a remote control shutter release to avoid motion blur.
IT'S A GOOD IDEA TO BRACKET.
Step 7: Samples
Here are a few samples made using this adapter and a Nikon D5000.
The D5000 is a good option because of it's live view funtion which makes it easier to focus as well as enabling you to take video.
Video test using spermatozoa:
greenthumbs says: Mar 24, 2013. 7:58 AM
I really hope that the above pictures aren't your spermatozoa.
CyborgGold says: Sep 13, 2010. 12:31 AM
Great idea! another use for this device would be for the exact opposite approach... a telescope. One could even turn a decent telescope into a really strong telephoto lens.
stephenniall says: Feb 13, 2010. 3:04 PM
Smart !  hehe Love how you said heres a few samples made
TheCheese9921 says: Aug 18, 2009. 10:28 AM
Sperm, lol
BobS says: Aug 17, 2009. 10:34 PM
Nice work! One word of advice about crazyglue and optics: Never work near lenses!!! The fumes of the glue react with traces of grease on the lens, forming stains. The police makes use of grazyglue to make fingerprints visible this way.
5inister (author) in reply to BobSAug 18, 2009. 7:38 AM
Thanks for the feedback and thanks for the advice on crazy glue, I'm sure it will be useful to others.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
