Not in the main case is my car tool kit, which contains virtually every tool necessary to completely disassemble my car on the side of the road. The heavy tools (crescent wrenches, etc.) stay in there, I can bring them inside if necessary. There is also a small case that sits on the closet shelf to hold a Versa-Pak-powered Wizard (Dremel-like rotary tool) and electric screwdriver, which are my compromise between keeping everything clean and quiet and having access to a Dremel and a drill.
Remove these ads by
Signing UpStep 1The Lid
- #2 Phillips
- 3/16" Flathead
- #1 Phillips, the screwdriver I got when I was five
- Smallest round rat-tail file with plastic hose as a protective sleeve
- Compact 10' Stanley tape measure
- Small vise grips
- Scalpel (used as a hobby knife that won't snap)
- Slip-joint pliers
- Compound-action wire clippers
- Combination wire cutters/strippers/crimpers
- My favorite machinist's hammer
- Bicycle spoke wrench
- Wee 1/8" flathead screwdriver
*I get the idea** that every American building over two stories has a hugely-complex flight of metal stairs that goes past every window as required.
**From eighties TV.
The dorm I'm living in consists of two nearly-identical five-story buildings. Each one has two elevators in the middle and a staircase on each end. The stairs on one side are fully enclosed and intended for everyday use(up and down). The other set can be accessed from the inside only on the second through fifth floors, and is intended only as a fire escape (ALARM WILL SOUND). The stairs themselves are outside, although made of concrete and brick, but access from the ground is blocked by a door with no external handle.
This fire escape side does lead to the roof on both buildings; there's a little raised part for the roof access door on both buildings visible from the taller parts of campus. So if I could get into that stairwell I could get to the roof, but that would require either a 12-foot climb up a flat brick wall to get to the second-floor landing, or getting through an emergency exit without tripping the alarm.
I decided a fume extractor would be easier. :P
Or is that Baywatch..?
