This is the home of the heavy stuff, and space is tight. The spread-out picture is a poorly-edited composite because the desk wasn't big enough,
see full image here. Loads of stuff in here:
Clamp-on vise, can attach to the edge of the desk.
Thin baling wire. This stuff fixes everything duct tape can't. Particularly toilets that your suitemate can break better than he can fix.
Thin hanging wire. Great for hanging things from the suspended ceiling grid.
Paint scraper -- razor blade on a big handle
Universal power adapter with a dozen tips, fits almost everything and goes from 1.5V to 12V.
Little jar of 1/2" stainless sheet metal screws, these little guys are handy
US/metric hex key set in sleeve, 1/16" to 1/4" by 1/64s and 1.5mm to 10mm by .5mm.
Precision/jewelers' flathead and Phillips screwdrivers. The cheap ones but they work.
100-piece security bit set. The bit I need to take apart the electronic door locks is in there...
26-piece ratcheting screwdriver set, with Phillips/flathead, star, and socket bits. Also works on the security bits.
Bazillion-function gauge
Two-part epoxy with little plastic tubs to mix it in
1/2" countersink bit
Matchbook
Automatic wire strippers
Third hand tool with the stupid bulky magnifying glass removed
Homemade 1.5V-12V variable power supply, uses a LM317T regulator.
BK 2704B multimeter
Needle and hook leads for the two previous
Seal-All tube. Stuff sticks about anything to about anything.
Kite string, for general tying purposes.
Safety glasses
Syringe of Browning gun oil. Very handy for applying light oil to particular points
WD-40 pen. It's the perfect size for a tool kit like this.
Smallish and largeish zip ties
Bottles of rubbing alcohol and trichloroethane. If the first won't take it off the second one probably will.
Large rat-tail file, split-loom tubing to protect it
Large 10" flat file, in plastic sleeve to protect it.
Gritty cut-through-anything blade on coping saw frame
Hacksaw on a compact handle.
New #2 Phillips, in case I need a perfect fit
Flat scraper (more razorness)
