PLEASE NOTE: This project uses high-voltages which are inherently dangerous. Additionally, I am not an electrician and can not verify if this project poses a fire-hazard. Lastly, I am pretty sure that the use of this project on other people's property would be illegal.
***Construct and use at your own risk.***
Remove these ads by
Signing UpStep 1Go get stuff.
1. A standard wall socket
2. An outdoor socket cover
3. A cell phone charger (preferably 5V 500ma)
4. Two grounded wall plugs (like the one below)
5. A 1" x 2.5" piece of lucite that is of 1/8" thickness
6. Electrical tape
7. Thick stranded wire (the one below is from a strand of Christmas lights)
8. A plastic 1/8" pull-tie (not shown)
to be explained in final step:
9. Casing and paint (not shown)
10. Epoxy (not shown)
Tools:
1. A Phillips-head screwdriver
2. A pair of pliers
3. A Dremel (or laser cutter)
4. A utility knife
5. Wire strippers
6. Soldering iron
The concept is a kool one but not a wise one. As far as wifi repeaters you would spend major bucks and have to but then all over just to cover a small area. Not to mention that if your ISP catches you giving out free wifi with intent it's very bad news (cancel service, and might end you up in court).
The one statement about the romex wire being able to stab into the back of the receptacle is correct but it only goes up to 14awg solid wire. Most Boxes are of the 18cubic in type and don't have a lot of room in them you would have to have at least a 22-24 cubic inch box. They do make extension rings for the outside ones and it comes with longer screws. From experience no matter how well you seal the cover it will get moisture inside and if your making one that have a PC board in it you;ll have to epoxy dip that board to keep it dry.
To be perfectly honest with all you would have to do to adapt a outlet box and such to achieve what you want isn't really worth it.
Easier just to get a pinhole wireless cam and mount it inside something thats already there (clock, smoke detector, light fixture, ect)
This wasn't the first time for something like this to happen and it won't be the last. Be mindful that people are afraid of anything different these days.
I'd also suggest paying attention to weatherproofing the box if it is intended for outdoor use. Water and electricity don't mix.
The wiring of the plug to sockets should be double checked with a 3-prong AC tester (e.g. U.S. model or U.K. style) - they are infinitely handy to have anyhow.
Heat-shrink tubing is more durable than electrical tape for insulating the wiring joints. And I find it easier to make a neat and tidy seal.
You might be able to make something like this picture. (Sorry for the lack of detailed schematics.)
Now that I think about it, it might be easier to just put the thumbscrews in the top/bottom so as to allow more room for the circut board. It might be better to use 1/4 turn screws similar to those that they use on race car bodys, to make it less tempting to exploring little boys....then again, I dont know where you would get something like that.
You could perhaps go for one of the rotating magnetic charger designs that capture your movement and turn it into electric for your stuff. Or this - Stealth charger
