Step 2Make the plug bracket.
The one you see was cut with a laser cutter that the Graffiti Research Lab was kind enough to let me use. I recommend begging, borrowing or stealing a laser cutter. Otherwise, you can use a Dremel to cut out the mounts. My first mount was done with a Dremel, so I know it's perfectly feasible. It will just take a little more work.
First take apart the plugs. Notice that there are three prongs and a mounting bracket that holds them straight. You will need all of this. However, at this point you need to take it apart completely.
Basically, each prong on the plug has a little notch on the bottom so that it can catch onto something and hold itself in place. So, the goal here is to cut out the holes so that when each of the three prongs are slid into place and the bracket put back on, they will all line up straight. This will take some trial and error.
For measurements I have included an approximate layout I quickly mocked up in Photoshop (unfortunately the file I was laser cutting from is no more). You are going to want to measure your plug for yourself.
Once all of the holes are cut and all three prongs are latched onto the lucite frame, you're then going to want to slide back on the yellow bracket that holds all three prongs in place. Please note that I cut a circle in the middle of the board. This is so that the bracket can press flush against the board (because the bracket has a little round protrusion in the back).
Once both plugs are in place and seem to line up straight, you are then going to want to see if they will fit into an actual socket.
DO NOT PLUG THEM INTO A LIVE SOCKET!
You should have an unused wall socket that is not connected to anything.
PLUG THEM INTO THAT! (as shown in the picture)
If, as shown in the picture below, the mount fits into the socket and lays flush to it, then you are good to go ahead to the next step. If not, break out your Dremel and keep at it until it does.
Add Comment
