Step 4Connecting the plugs and the socket.
MOST IMPORTANTLY, this new device will ALSO be powering a low-voltage DC device. Basically, one of the plugs connects to both terminals on the new socket and the other plug will run off to a cell phone charger (which is basically a really compact transformer).
So, the first thing you are going to want to do is cover the backside of the plug bracket with electrical tape in order to insulate it. Then, line up the bracket on the back side of the socket and use the plastic pull tie to hold it in place. That way, if you were to plug it into a socket just then (DONT!) it would be powering both plugs, but at the same time look as though a socket were facing you (see pictures).
There should be three wires running off of the socket. Connect all the wires to one of the plugs as follows:
1. The wire on the left side connects to the left prong
2. The wire on the right side connects to the right prong
3. The ground wire connects to the bottom prong
It should look like the picture. Once the two parts are tied together you can then attach the outdoor plate. After this it should look kind of cool.
Add Comment
