Step 5Break the cell phone plug.
Once you have established that there are simply two wires under the black covering, cut it so that you only have about 6" of wire left. Strip off the ends of each wire. These are your low-voltage DC connections. They will connect to ANY low-voltage DC circuit that you want to attach to them.
The next step is to prepare the transformer (the large block part) to connect to the unused plug on your bracket. This is easy. Take your pliers and fold each prong sticking out of the transformer back and forth until each prong snaps off.
Now you should have two terminals flush to the transformer. Solder two thick stranded wires that are 4" long and stripped on both ends to each of the terminals. Wrap the transformer box in electrical tape.
Add Comment
