This versatile work surface is perfect for cooking because it is close to kitchen counter height (home counters are typically 36 inches). At 30" tall this table sure beats having to tend to a stove on the ground.
Some ultra light backpackers may consider a table an unnecessary luxury who's weight they can forgo. For me, the utility and convenience this little table provides is worth it.
When I camp I am willing to do with out the Lazy Boy, the Zenith, and the microwave..... but at least let me keep the TV Tray Table.
The 14" diameter work surface is more than adequate for cooking with a stove, mess kit and water bottle. Note: Be sure to check the Instructables link in step 10 for two light weight stove designs that have been used with this table.
Photo four on this step shows the table easily supporting the weight of 9 liters of pop.
Remove these ads by
Signing UpStep 1Description
A fabricated wood block couples the tent pole arms and legs to complete the table's support structure. The complete structure weighs 1 lb. including the wood block and all the hardware and stakes.
The actual table top is a pizza cooking tray. The one I found had pre-punched holes for crisping the pizza (which has the benefit of making it lighter) and although it is steel, it only weighs 1 lb. I am on the lookout for an equivalent 14" diameter aluminium tray which would reduce the weight by about 1/3.
I found that the 14" diameter is a good workable size. Anything larger would require a wider leg stance to maintain stability and besides, 14" is the largest size that will fit within the width of my pack.
I'll try on my side to get something proper. I don't where to find the pizza round plate so will be looking for thin aluminium sheet
But then, ''DIY yourself'' ( as it was put) is why we're here.
It's more fun that way.
I don't care what you 'ultralighters' say, cooking on the ground sucks just as much as sitting on the ground. I do consider myself a 'lightweight' hiker, but a few comforts do make a difference for me.
