3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Campfire Toasting Fork
This instructable tells you how to make a really easy toasting fork, for use on campfires. It takes about 30 seconds to make and can be made with just a penknife.
Step 1Tools/Materials
Tools/Materials
You need:
A penknife, preferably locking for safety. (I used  Victorinox Skipper)
A stick, about 1/2 an inch thick and as long as you want the fork to be.
Another stick, about 3 inches long and 1/4 of an inch thick.
46 comments
1-40 of 46next »
Mar 31, 2012. 11:22 AMfreeza36 says:
I will post a pic of mine later today
Nov 30, 2011. 2:32 PMfmurillo gomez says:
u can also make in bigger scale to catch fishes at a river but use preferebly a bamboo stick with a diameter 1.5in or 2ins.
May 5, 2011. 8:48 AMfeibiao says:
simple and useful i'll have a try next camp
May 17, 2011. 5:58 PMyugiohmaster2323 says:
im camping this friday
Dec 2, 2010. 7:09 AMsteve_tupper2010 says:
Nice job, AntMan232. If you want to go one stage further, would point out that this can also be used for spearing things, fish mainly, if you trim the points a bit and maybe make the project a little larger overall. Instructables like this are great - useful but simple. I shall be using this on my next camping trip, that's for sure.
May 15, 2011. 6:50 PMyugiohmaster2323 says:
GOOD IDEAR
May 5, 2011. 3:05 PMostomesto says:
im doing the fish thing! great idea
Sep 4, 2010. 9:55 AMPurple Guy says:
I made this today. The main bit of wood was perhaps a bit thin and also wasn't very straight so I might make another tomorrow? : )
May 15, 2011. 6:49 PMyugiohmaster2323 says:
thats not nice its a great idea IM GOING TO MAKE IT HUMPH
May 5, 2011. 3:06 PMostomesto says:
of course someone's gonna make it. this is one of the things that are useful, awesome, and creative yet take only a couple minutes to make. im bored and have nothings to do so im gonna make one now. its easy and useful, thats what makes a good ible'
Oct 17, 2010. 2:16 AMCamWaite says:
I will hopefully take this design to scout camp in the next few weeks!
Oct 3, 2010. 1:47 PMPurple Guy says:
Thanks for the patch! :D
Sep 4, 2010. 10:06 AMPurple Guy says:
what sort of wood did you use? just so I know
May 7, 2011. 3:09 PMninja_maker says:
Hey also u can soak the front in water so that it doesn't catch on fire.
May 7, 2011. 3:07 PMninja_maker says:
ive gone cmapind before and never seen someone make this. this time im goin to be roastin 4 marshmallows at once while they're still roasting one.
Nov 29, 2010. 10:10 AMchuckr44 says:
Hm. I bet if I put a hotdog between the "tines", then remove the cross sticks, the tines will squeeze the hotdog enough so it won't fall into the fire.
Oct 12, 2010. 6:04 PMColiflower says:
Great 'ible, 5 stars.
Good idea and design, I may try this when I go camping this coming summer.
Sep 5, 2010. 9:11 PMdropkick says:
Great hotdog or marshmallow spear, and it would work for holding and cooking meat. But if green willows are available I'd rather make a grill and fry my burger on it. Bend a larger branch into a u-shape, tie the ends together, and weave smaller branches through each other and the u-shape. (Bad drawing below) While traditionally used for frying fish, I've cooked burgers and steaks on them before.
Sep 1, 2010. 11:49 AMspenfisher12 says:
this can also be a frog gig
Sep 27, 2010. 1:32 PMPentacle says:
Very true!
Sep 5, 2010. 2:29 PMjanettetsmith says:
Ew.
Sep 7, 2010. 3:56 PMspenfisher12 says:
dont go camping if ypu cant handle the grosser things
Sep 7, 2010. 6:37 PMjanettetsmith says:
I go camping plenty and never found the need to gig a frog. However, that doesn't mean I wouldn't eat me some frog legs if someone else did it.
Sep 7, 2010. 3:54 PMspenfisher12 says:
if there are less than 5
Sep 9, 2010. 1:16 PMbrickman93 says:
so what exactally do you toast with this?
Sep 5, 2010. 2:45 PMkumo says:
Concerning the choice of wood, hazel is a favorite around here. (I'm from Switzerland). In Europe, you're never far from an hazel tree, which technically looks more like a bush. Easy to split straight shafts with straight grain, very flexible wood, very workable with basic tools (say, a pocket knife of the swiss variety), tasty edible nuts. Birch, once stripped from its bark, would be be very usable as well.
Sep 1, 2010. 12:16 PMPurple Guy says:
Good 'ible, I might try tomorrow but I can tell that I'll just end up splitting the wood in half or it snapping with my luck!
Sep 3, 2010. 10:43 AMBroom says:
Make sure your stick is green, and it should be less likely to snap.
Sep 4, 2010. 9:13 AMPurple Guy says:
Aug 31, 2010. 8:21 PMfireraisr says:
this is more commonly known as a frog gig or fishing spear. I'm sure it makes a great campfire fork as well. an important thing to note is the type of wood you use for this. Sure you can make it out of anything but certain woods are toxic and can actually poison your food. If you aren't sure, pine is always a safe bet (outdoors-man fact: every part of the pine tree is edible, from the needles to the inner bark. Many campers enjoy pine needle tea)
Sep 4, 2010. 8:51 AMFoaly7 says:
Yeah, you can set up camp by a river, make one of these, stab a fish, then take it straight to the fire and cook it up.
Sep 3, 2010. 10:46 AMBroom says:
Cashews, yew, black cherry twigs (but mostly the bark, so peeling the bark off the sticks should make them safe), and a few others. Most are perfectly safe.
Sep 1, 2010. 10:07 PMCimarron_warrior says:
if you are out in the bush you could use some small vines and tie around the base of your splits and that would also help to kep it from spliting further.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:AntMan232
