3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camping tips and tricks
For over 30 years my family has been making annual trips to Vermont to go camping in the late Fall.  Over the years it has grown from being just four of us (my Mom, Dad, Sister, and me) to over a dozen people, family and close friends.
I know a lot of people on instructables are into backpack camping, so they have to be careful about the weight of what they are bringing since they have to carry it in and out.
Odds are these tips won't be of much help to you.
Our annual trip is by no means considered lightweight.  But we bring the things that make the camping trip fun and comfortable.
*8/20/2011*
updates to step 3 and step 4
added step 7
*8/21/2011*
update to step 4
*8/24/2011*
update to step 4
*9/3/2011*
added a link to the recipe for Mom's Beef Stew in step 4
Step 1Lean-to Tarp
Lean-to Tarp
The state park has really nice Lean-to sites available.  A Lean-to is really nice for getting you up off the ground and providing protection from the elements.  The only down side is that the entire front side is open to the elements.
For years we would nail a tarp up to the front of the lean to using the grommets on the tarp.  If it was nice out we would string the tarp out to make an awning over the picnic table (we would move the table over to in front of the lean-to).
If the weather got really nasty, or if we were turning in for the night, we would drop the tarp down to cover the front of the lean to.  The tarp helps to retain heat, as well as keeping out any nasty weather.
A few years ago we picked up a 10' square pop up tent.  Since We started using that over the table, we have not needed to use the tarp as an awning.
In order to make it easier to get in an out of the lean-to during the day I came up with a new way of setting up the tarp.
By stringing a length of rope across the front of the lean-to and inserting shower curtain rings into each of the grommets in the tarp.  It makes it very easy to slide the tarp off to one side during the day so it is out of the way, and then slide it back into place at night.
83 comments
1-40 of 83next »
May 21, 2012. 4:41 AMtim_n says:
Many thanks for the link and compliments :)
Apr 24, 2012. 7:04 PMsconner1 says:
I used rinsed out box wine bags for water.
They collapse and take less space as they get used up Plus have a dispenser cap already built in.
Apr 29, 2012. 2:13 PMsconner1 says:
Take the bag out and the dispenser cap either unscrews or pops off with a flat screwdriver. I forget which, it's been a while. There may be brands where there's no cap or it doesn't come off. Look around.
Apr 24, 2012. 7:13 PMsconner1 says:
Dryer lint and a flint/steel is all you need.
Or steel wool and a 9V battery can be fun.
Newspaper, rolled into a rod, tied with bits of twine, cut to 1-2" lengths and dipped in paraffin wax will light even slightly damp kindling.
Apr 15, 2012. 6:19 PMmedievalpirate says:
Another cheap fire starter is to use pine cones, send the kids out to find them, then store in a plastic bag. Use two or three along with some screwed up newspaper under your kindling... the only thing your paying for then are the matches.
Apr 16, 2012. 2:24 PMmedievalpirate says:
No problem, may have to share a recipe or two with you guys. They are full blown camp cooking, none of this starting it at home and then reheating onsite...
Sep 8, 2011. 11:46 AMleonal says:
Bears have been known to break windows or rip doors off hinges. If you're in bear country, use bear boxes if available or string your stuff up in a tree if not. Most cars prevent very little challenge to a motivated bear.
Apr 14, 2012. 9:33 PMde0509 says:
solution number #2. get a gun license and a gun XD. just kidding. Now that bears have been mentioned I wont ever feel safe in the forests.....
Mar 12, 2012. 2:02 AMimpropergentleman says:
In the south, Bears aren't to big of a problem. Camp bears (raccoon) can figure out about anything you do to hide food. Check out BSA Scouts sites for ideas.
Feb 7, 2012. 8:17 PMyoubaka1 says:
hey is that on long island that campsite i think i recognize it
Aug 21, 2011. 1:52 PMkillersquirel11 says:
Knowing knots can help make those last-minute improvisations possible.
The ones which anyone who goes camping should know:
Taut-Line Hitch:  A slip knot that stays in place until you adjust it
Square Knot:  Good for securing items, but tension on the wrong pair of ends will turn it into a double-half hitch
Trucker's Hitch:  Good for when you need a really tight line.  Basically a pulley system.  According to the linked website, it offers a ~1.6:1 mechanical advantage after friction is taken into account.
Not as necessary, but still useful:
Square lashing and clove hitches can be used to improvise many implements for around the camp (although round lashing can be used for making a tripod).
My personal fire starter is birch bark.  It's quite common where I go camping, so I don't even have to remember to pack anything special.
I also seem to remember reading a few instructables about fire starters a while back.  Many of them seem to use some combination of dryer lint, wood chips, and wax to make something that lights easily, lasts long, and lights damp.
Aug 24, 2011. 2:17 PMkillersquirel11 says:
I listed the knots that I tend to use. I don't know why, but I've never really used the bowline.
I also do the trucker's hitch a bit different than anywhere I've found online. The starter knot is a simple slip knot, and I finish it off with a few half hitches. As long as you are careful to make the free end be the one that controls the size of the loop, you gain a bit more mechanical advantage. Granted the trucker's hitch already tends to be good enough to snap some flavors of twine....
One other thing that I forgot is a good way to store rope. Something like this: (It's called a butterfly coil in case youtube decides to be stupid)
Dec 24, 2011. 6:52 AMTonkanhootie says:
That's awesome, Thanks!
Aug 21, 2011. 10:09 AMAllenInks says:
Re: fire starters: Have you tried cotton balls soaked in Petroleum Jelly ( such as Vasoline brand)? Put one on a small bit of tinfoil, and light it. It burns for several minutes, and is nearly windproof. The tin foil reflects heat, but more importantly, retains the petroleum jelly after it melts into oil, so the cotton fibers act as a wick for the oil, like a candle, so it burs much longer.
you can carry several with bits if tin foil in a leak-proof container, such as a waterproof containersold to hold matches for camping. load each cotton ball, presoaked in petroleum jelly, with an individual patch of tinfoil, say 2.5 inches in diameter, in the middle of a respective u-shaped bit of string, so that each cotton ball and folded tin foil base can be retrieved by pulling the ends of the associated length of sting. all the string ends are kept near the mouth of the container as you pack in the balls.
Aug 28, 2011. 12:59 PMjimbru says:
About firestarters; I have noticed that a lot of contributers from the US seem to be relying on them. I am a bit surprised as a bit of woodcraft would suffice.
In my scout corps we teach the scouts from age 10 and up to make fires without firestarters in normal conditions. (Normal would mean temperatures from -15 to +30 degrees Celsius, from sunshine to light rain and not too much wind, probably less than 6 m/s, when they can do this and from about age 13 we challange them with more severe weather conditions)
They get a small axe, a knife and 3 matches for the firestarting to get the merit badge. Of course there is some other requisites for getting the badge, like knowing where to find kindling and wood, types of wood and their qualities and a number of types of fires for different uses. We have seen that after they learn this they take pride in knowing how to make a fire and doesn't need any firestarters.
What will you do if you use up your firestarters? What if you loose them? When you don't practice your skills you'll loose them too. :-)
Keep camping and start your fires "naturally".
Happy trails, Jim
Oct 31, 2011. 8:39 PMmkslocomb says:
just to add that cheap note... my first time camping, my dad did buy a firelog, we cut it into eight pieces, ziploc baggied them and ta-da... really inexpensive fire starters ( i think my dad didn't believe i could actually start a fire ?!?!) also, newspaper wadded loosely works well.
Aug 21, 2011. 11:12 PMgeppetto425 says:
After breaking the glass on our propane lantern I found a replacement made of a durable metal screen that still let's plenty of light out! In stock at your favorite camping store.... the tinfoil is a great idea. So are headlamps, our scouts love those.
Sep 9, 2011. 2:44 PMtjesse says:
dang, I just trashed a lantern because the glass was to expensive. Now I know that screen works.
Aug 31, 2011. 8:16 AMMrballeng says:
Any room in that mini van for 1 extra person? (like me). Thanks for taking the time to post this.
Sep 8, 2011. 6:15 PMbrothertuck says:
I'll take that seat, but I don't change diapers, did that enough already.
Aug 29, 2011. 10:08 PMklimb says:
Yeah, Where I camp we have to worry about Bears and Cougars, who will be able to rip through any rubber container if it smells something it wants. These animals are not fearful of people at all, and the pickings are easy where people are around. One thing you hear of every summer is someone putting coolers in their tent and having a bad encounter with a bear. DO NOT LEAVE FOOD IN TENT OVERNIGHT!! They can smell through your double walled cooler. I still go with the old put it in the car trip but when you hike out to your camp spot and don't have a cooler, make sure to store food as far away from camp as possible, and tie it in a tree if possible.
Aug 30, 2011. 1:13 PMklimb says:
Very true. Fortunately warnings are posted at most campsites nowadays but not before some had to learn the hard way. These are some great tips for your everyday family camp types, good to see tips that aren't centered around the super serious backpacking types, useable for families. Makes me want to go camping so bad! I'll have to remember that whistle one next time, thats a great idea. Don't forget the sunscreen either!
Aug 30, 2011. 3:16 AMseamster says:
There's a ton of great stuff in here. Thank you!
Aug 27, 2011. 10:08 AMyoubaka1 says:
hey is that west hills on long island new york?
Aug 24, 2011. 3:32 AMJesse USMC says:
If I use a plastic container for food or a cooler full of food I ratchet strap it shut. Coons have opened my coolers without a strap on them before. Putting food in the car at night is still safest in my opinion.
1-40 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:Lorddrake
Jack-of-all trades, master of some. I would probably be much more modest if it wasn't for these delusions of granduer that I suffer from.
