3 Simple Ways to
Share What You Make
Other ways to share:
Crushed Can experiment!
by
Miro95
How To Make Slime - Method 2
by
sciencebob.com
How to crush a can in less then 30 milliseconds with only a can water and a heat souce.
by
Run N Gun
Science Experiment: Inflate a Balloon with Vinegar & Baking Soda
by
sciencebob.com
Edible Chemistry from the Microwave!
by
imshanedulong
How to Demonstrate Soda Density
by
kentchemistry.com
Improvised Gas Mask
by
TimAnderson
© 2012 Instructables
All Steps Viewing
Slight correction to the explanation - you didn't just heat the air in the can, you displaced it. The steam from the boiling water replaced the air. When you cooled the can, the vapour condensed, decreasing in volume dramatically, creating a vacuum.
You don't need the ice for it to work, cold tap-water is fine, and if you use deeper water, you sometimes get a satisfying smack sound as the water rushes in and hits the inside surface of the can.
