3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Can Legos Compute?
Can Legos Compute?
No, Legos can't compute, but you can build a Lego Computer. I had assorted computer parts but no case for them. I also had a few thousand legos. So I decided to build a computer case from the legos.
Step 1Lay out all parts of Computer
I inventoried all of my computer parts to make sure I wasn't missing anything important. I had a CD drive, a diskette drive, a motherboard, a hard drive, a power supply and all cables needed to connect them. I also had a mouse, keyboard and monitor.
50 comments
1-40 of 50next »
Jan 9, 2008. 5:44 PMcarebare47 says:
That case is practically sealed apart from the psu fan and the hole at the back and because its made of lego, the whole thing would start to melt within an hour.
Jul 7, 2011. 1:56 AMzack247 says:
-cough cough- i know this is a really old comment... and i apologize.
but you would be surprised how well legos actually stand up to the heat, ive had legos sitting out in the sun for several hours on a hot summer day and they are just like all the other legos, except the legos from outside were a bit more faded.
Feb 4, 2012. 6:22 AMa480641 says:
yes, LEGO which are made of ABS, will not melt until 221'F but not especially great above 176'F
if you add one or two fans and raise the motherboard off the base by about 1/4 or 1/2 inch, it'll be fine
Jul 8, 2011. 3:25 AMcarebare47 says:
In that case, I'm going to make myself a lego computer case! =D
Jul 7, 2011. 1:58 AMzack247 says:
this thing is so interesting!
if i were to make one, it would have to be a tower, but instead of those bumpy lego edges, i would probably use those smooth pieces just to give it a cleaner look, i would try this but i definitely dont have enough lego to do it, i have a fair bit, but not enough for something as big as this.
Dec 7, 2007. 2:57 AMfrosty1433 says:
floppy disk drives and legos are soooo 1998
Jun 5, 2010. 8:14 AMdungeon runner says:
Yeah, everyone says that until it turns out they put something useful on one of those things ;).
Who's from 1998 now?
-Y
Feb 22, 2008. 8:08 PMXellers says:
Actually, legos can compute. It is possible to make a simple mechanical computer from legos. Also, the lego mindstorms bricks are microprocessors that can run simple robot programs.
Jun 5, 2010. 8:10 AMdungeon runner says:
Yeah, there's been a lot of buzz on the webz on someone making logic gates with legos. Mechanical computers are absolutely fascinating, even when you know exactly how computers work.
I've seen four or five K'nex computers through obsessive googling. If it is as interesting to you as it is to me, then I eagerly await your lego computer :).
-Y
Jan 30, 2010. 5:49 PMSpeedStrikerXLR says:
 OMG!!!!!!!!!!!! that is so awsome
Id so make that if I had lots of legos
I hove bionicles though
Oct 27, 2009. 7:27 AMTrainguyxx says:
now, you have to try making a larger tower XD
=/ maybe even a server tower? lol
Aug 8, 2009. 10:45 PMAwsumsoss says:
i love this
Apr 4, 2007. 7:18 PMTheCheese9921 says:
I plan on building my next pc in a freezer but I'm worried about frost n stuff of and williz its dude, dood is an infected hair on an elephants butt
Mar 27, 2009. 5:01 AMcountable says:
Condensation on the motherboard will be the biggest problem. If you ever brought something that had a little sachet of silica gel (it will say dessicant, throw away, do not eat on the side). Collect a huge load of those (or get them from somewhere cheap), open them up and sprinkle all the stuff around the bottom of the freezer. Cheap solution to an expensive problem.
Jul 12, 2009. 2:06 AMVissy says:
They are mostly used up by the time you get them. I see cooling issues being more of a problem than this.
Jun 20, 2009. 2:07 PMroastprof says:
you can make logic gates out of lego, so a computer could be made completely out of lego lol it would take a lot of lego and space though.
Apr 12, 2009. 12:17 PMkenny94 says:
Mar 31, 2009. 10:50 AMpie_lover123 says:
I think its a nice idea, but it seems that you ran out of rectangular legos before your casing was complete. It prolly would be better if you built it vertically and bolted all your pieces to the inside, and then added some lego hinges to one side for easy access. (and CA them all together.)
Dec 10, 2007. 3:05 PMRodancoci says:
Nice one. Very cool. It gave me a GREAT idea, which, of course, I will not reveal untill the instructable.
Mar 11, 2009. 11:32 AMtinkerC says:
Please message me after, so I can see it.
Jul 29, 2008. 11:27 AMcormac3050 says:
Message me as well! sounds exciting!
Jun 30, 2008. 12:51 AMmwwdesign says:
This sounds cool. Message me when it's up, so I know which one it is!
Jan 4, 2009. 10:56 PMcornflaker says:
So that thing is running without a CPU video card, and sound card? :P (Yeah I know sound cards are pretty much always onboard now and the video card is sometimes too but I'm pretty sure I can see them sticking out the back of it lol)
Oh and a lan card... :P
Oct 22, 2008. 6:39 AMchrisman01 says:
Sweet! I'm in a computer repair class right now; I'm going to ask my teacher if we can make one!
Jul 29, 2008. 11:40 AMcormac3050 says:
Sweet! we have an old windows 95 pc gathering dust in the attic, I'm going to try make a lego laptop out of it!! will post photos when done.
Aug 1, 2008. 5:49 AMcormac3050 says:
sorry, its 98
Jul 30, 2008. 8:30 AMcormac3050 says:
What OS do you have on it?
Jun 29, 2008. 6:21 PMlivesteamfan says:
This is pretty cool. For me, I took the parts I had laying around and mounted them on a piece of 1/4" plywood. Everything is showing, motherboard hard-drive, I even took the cover off the cd drive. I'm running XP on this thing and it's better than my store bought computer that I now don't use. Also, I found that putting a fan on the hard-drive helps it run better because it stays at the same temp.
Jun 9, 2008. 1:36 PMcomputer41 says:
Wouln't everything melt from the heat coming from it?
This isn't any better probably far worse but thought it was amusing:
http://img73.imageshack.us/img73/1852/p1010044qy7.jpg
http://img73.imageshack.us/img73/2315/p1010045jr4.jpg
Jun 16, 2008. 8:11 AMGrey_Wolfe says:
If it's an ITX motherboard, then it really wouldn't be worse. They run remarkably well in such confined spaces. The boards run fairly cool, actually.
Apr 29, 2008. 1:28 PMcomputerwhizkid42 says:
Nice! two of my favorite hobbies are legos and computers! What kind of hardware does it have inside (e.g. memory, video card, hard drive) , and how does it run?
May 5, 2007. 12:21 AMMad Cat says:
Good idea, but it looks kind of bad. Sorry. Someone should try and make one out of K'nex.
Mar 23, 2008. 7:08 PMzero838 says:
it would look better if it was all one color
Feb 22, 2008. 7:59 PMXellers says:
K'nex would be much worse! Just a neater job with legos would make a nice case.
Feb 24, 2008. 10:17 PMMad Cat says:
Lego would be better at making solid, smooth surfaces, but K'nex can make a much bigger case without using up as many pieces.
Feb 28, 2008. 1:09 PMXellers says:
True...
Feb 3, 2008. 12:15 AMcbehrle says:
I laughed for at least 10 minutes when I saw this. it's very creative. I wish I had thought of it first.
Jan 8, 2008. 4:33 PMSypran says:
grr i can only do this for my old comp made in 95 or somthing. for my new computer that im useing is the big one that G4 made where its cost like a little over $3,000... i would do this with it to give it style but a super comp needs to breath
Dec 12, 2007. 5:16 PMthe_burrito_master says:
nice I would make a bigger case that could hold up every thing.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BPF722
