Step 1: Cans
At first you need a lot of cans... about 350-400!
I decided to use RED BULL COLA cans because of two reasons.
First one: i like the colours and their combination in this diagonally way.
Second one: some cans are made out of aluminium, others are produced out of tin-foil (coca-cola). Red Bull uses aluminium. The advantage of aluminium is, that you have no corrosion (rust) at the cut edge and its much easier to cut and to punch!
The disadvantage of aluminium is that its not that ductile, tin-foil is more ductile, and therefore it breakes easier when you start buckling it 2 or 3 times at the same place... but if you act carefully with your suit, this is not a problem ;)
The gloves for this suit aren´t part of this instructable, they have their own and can be found here:  http://www.instructables.com/id/LED-Gloves/
1-40 of 59Next »
bobert610 says: Aug 31, 2012. 6:55 AM
Bravo! This is awesome man! The craftsmanship is fantastic!
KneXtreme says: Aug 31, 2012. 5:45 AM
Wow! That's amazing! The last picture is awesome.
FriendOfHumanity says: Aug 31, 2012. 3:09 AM
That is just incredible: nice job.
firepup104 says: Nov 3, 2011. 6:52 AM
Is it aluminum foil like at a grocery store?
AlternateLives in reply to firepup104Aug 30, 2012. 7:25 PM
If you're asking about the rolls of aluminum foil...
Not exactly. The stuff you buy on rolls to cook your turkey or what have you is much, much thinner than the stuff they make pop cans with. (I'm a midwesterner, and that's what we call those. Deal with it.) That's why it crumples and punches through so easily.
It is almost impossible to use Reynold's Wrap to create something like this (unless you're up for melting it down and hammering it out), if that's what your asking.
wobbler says: Jul 22, 2012. 6:50 AM
Is it a Bull? Is it a Cola? No, it's Can Man!
Those who can do, those who can't can always make a can suit.
jgonzalez-2 says: Oct 12, 2011. 10:17 AM
i bet with all that red bull he was up for a week or two making that suit. with all that time in it. it did come out pretty good. one question though... any problems with getting cut by the edges of the cans ?
Prototyp 81 (author) in reply to jgonzalez-2Oct 13, 2011. 1:50 AM
no, i wear long johns and a longsleeve shirt...
jgonzalez-2 in reply to Prototyp 81Oct 13, 2011. 1:36 PM
is saw another question posted about where did you get all the cans from ? dont remember seeing the answer. so where did all the cans come from.. and if they were all bought periodically by yourself. how long did it take to get em all. thanks and thumbs up on your build
Prototyp 81 (author) in reply to jgonzalez-2Oct 14, 2011. 10:50 AM
i answerd this question already further down... got these cans (empty) from red bull!
TimmyMiller says: Oct 11, 2011. 5:46 AM
where did you get the cans?
TimmyMiller says: Oct 11, 2011. 5:45 AM
very patriotic.
djimdy says: Sep 29, 2011. 10:47 AM
Hang on. Not to be pedantic, because this actually does matter, but "tin-foil" is aluminium. Not many people actually use foil made of real tin (Sn, element name Stannum, the dominant component in regular, rosin-core electronics solder).
Not only that, but were your cans made of actual tin, they wouldn't rust at all (nor would they hold much pressure) -and- they would in fact be a piece of cake to cut.
While it's also true that true tin foil is more ductile than aluminium, ductility does not in and of itself lead to breakage. But you're not using tin, you're using 2 thicknesses of aluminium with differing amounts of work-hardening, which actually does determine resistance to breakage.
Steel cans, on the other hand, will rust, weigh a lot, are hard to cut, harder to find, harder to shape, etc.
Just thought you guys should know.
Prototyp 81 (author) in reply to djimdySep 29, 2011. 11:38 AM
Thank you for the information. Perhaps i am not that good with these technical terms but for me tin-foil is not foil made out of real tin... Its a thin sheet steel coated with tin...
djimdy in reply to Prototyp 81Sep 29, 2011. 12:01 PM
You probably mean thin, galvanized steel sheet. If it was actually tinned steel, that would be pretty useful, since it means you could solder directly to the sheet and make lots of really great things.
In any case, nice job with the design and construction!
mysss in reply to djimdyOct 6, 2011. 2:16 PM
He means tinplate, which is what most food cans are made of. (Or at least they used to be?) That's mild steel plated with tin for foodsafeness and corrosion resistance. I don't come across many Coke cans, but I thought they were aluminum too, so...doesn't clear up the issue entirely I guess.
Ceiling cat in reply to mysssOct 10, 2011. 4:25 PM
I don't know what Coke and other soda cans are made of where you live, but here in the US they're made of aluminum. I very rarely come across drink cans that are made of steel or tin. Just thought you should know.
Very cool suit, by the way! Great construction!
CC
Nachoman says: Oct 8, 2011. 2:09 PM
Epic.
nbrown-1 says: Oct 6, 2011. 7:28 PM
Would you be able to update the instructable with a list of what those tools and materials are for those of us who can't recognize them just by looking at the picture?
I'm trying to make a suit of armor like this, and it would really help to know what exactly I'm buying.
Thanks!
Prototyp 81 (author) in reply to nbrown-1Oct 7, 2011. 3:34 PM
Ok i will try!
Cutting:
1: I used metal shears to remove the bottom of the can which is harder than the rest of the can and to cut the steelband and the tinplate.
2: For the rest of the can i used a ordinary shere.
3: To punch the holes in the can pieces i used a hole puncher and a punch pliers.
Connecting:
4: To connect the can pieces to each other i used a grommet pliers. (The Grommet diameter should be about 1 mm smaller than the hole diameter --> can pieces stay movable)
5: For the places i couldnt reach with the grommet pliers or that needed a more solid connection i used a blind rivet pliers.
Materials:
6: Steel band to structure some parts like the helmet or the shoulder component.
7: Tinplate for the same reason but its more flexible than the steel band and can be used at other places.
8: Gloves for your saftey!
9..... CANS!!!
I think these are the most important things you will need everything else is optional and i`m sure there are several other ways and tools that work as well as mine did, or even better!!!
As said, these tools were used to work with aluminium cans!
What is more, the tools aren`t that expensive... the absolutely most important thing you will need is a lot of time!
nbrown-1 in reply to Prototyp 81Oct 7, 2011. 4:16 PM
Thanks a bunch! That's really helpful.
chicopluma says: Oct 4, 2011. 7:50 PM
Red bull gives you (wings) an amazing armor
mjackson4 says: Sep 30, 2011. 11:03 AM
haha! You need to try for sponsorship after making that suit!
daltman russell says: Sep 29, 2011. 6:45 PM
I've got to say this is so cool and I love it !
Highjumphero says: Sep 29, 2011. 2:47 PM
Better than a can't suit!
CRHazardous says: Sep 29, 2011. 1:55 PM
Did red bull send you empty cans?? Did it cost you for the cans? And how much?
Asa J says: Sep 29, 2011. 1:47 PM
Pretty sweet, but I would probably trip and bleed to death from a million tiny lacerations.
angelabchua says: Sep 29, 2011. 1:20 PM
Oh my word! This is AMAZING! Please tell me that the folks at Red Bull have seen this?! Amazing job!
dangerine says: Sep 29, 2011. 11:52 AM
How did you make the knee joints bendable? Can we get some more photos of the knees, elbow, shoulder areas to see how it moves? Maybe a close up of how you layer the pieces for the rivits?
Prototyp 81 (author) in reply to dangerineSep 29, 2011. 12:45 PM
no problem, i will add them tomorrow!
jkbrigman says: Sep 29, 2011. 11:15 AM
Double rainbows!
instruct39 says: Sep 25, 2011. 1:27 PM
ver cool, just needs to be alot more described and have a few more pictures to be a full instuctable though
noire in reply to instruct39Sep 29, 2011. 10:07 AM
yes, this really needs more detail. at this point of development it's less 'Instructable' and more 'Likes'-trolling.
Prototyp 81 (author) in reply to noireSep 29, 2011. 10:25 AM
i am working on it... more pictures more discription!
AxlTxl says: Sep 29, 2011. 8:51 AM
That's really a cool suit! And it's done very well!
just a silly question... did that suit give you wings? :D
nice job, bsenger!
psbuckley says: Sep 29, 2011. 8:20 AM
Excellent job!
I understand why people want MORE DETAIL!!! However, I tend to think it's fine the way it is. Do they want a suit EXACTLY like yours or do they want to improvise in a few places. They will likely have to do that anyway because of their body type.
Anyway, keep up the good work!
Maybe Red Bull will give you wings next!
Chakazuluu says: Sep 29, 2011. 8:02 AM
Excellent project - just not enough detail...
askjerry says: Sep 29, 2011. 6:26 AM
It's hard to tell from your instructable, do you pop rivet the cans together directly, or to a piece of cloth to act as a flexible medium? Actually... they don't look like pop-rivets... what kind are they?
Can you show more detail on the construction part? You have great photos of the completed item... and some good photos of the tools and prep work... but the actual INSTRUCTIONS that make this an Instructable... they are a but vague.
You could include things like...
1) How you calculated the layout / shape.
2) How the parts were joined.
3) What did you do differently at the joint areas.
4) How many sections, and how are they held together.
Thanks,
Jerry
CodySteed in reply to askjerrySep 29, 2011. 7:31 AM
They look like very short, prolly 1/8 inch aluminum pop rivets.
Prototyp 81 (author) in reply to askjerrySep 29, 2011. 7:10 AM
Ok, this evening i will add some pictures with more instructions :)
1-40 of 59Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
