Then want no more this simple, affordable table is perfect for you and the same method can be adapted for almost any piece of furniture.
This Instructable is a restoration, of sorts, on an old table which was saved from the going to the landfill.
Remove these ads by
Signing UpStep 1: What You Will Need
You will need:
Paint, any it's personal personal preferance here, I chose chalkboard black so it could be drawn on in chalk
Sandpaper, I find 100 grit is perfect
A paintbrush
All the usual gear for painting ( cleaning fluid, newspaper to keep things clean etc)
A donor piece of furniture or you could make your own
Cans , I can't really be exact here as no two will be the same but I ended up using ten, the table will look a lot better with a wide range of colours so I felt Barr cans were perfect as all the different flavours have a different bright colour
Adhesive of some sort, I used a fast setting tube of adhesive which is used with a caulking gun, but almost anything would work
Scissors, a blade or a tin opener, whatever you choose to use to cut your cans
Visit Our Store »
Go Pro Today »
Ross
