Intro: CanardWings - a variation of Paperang, a cool paperplane/glider
This is a variation of the famous Paperang. I found the Paperang works, but does not fly as well despite tweaking the trailing edge. I began to explo...
First print out this trailing edge curvature for the wings.You may also want to experiment with different curvatures.After printing, cut along the cur...
Use a fresh sheet of A4 paper, place it on a table with the long side towards yourself.Fold in half, aligning the edges as accurately as possible. Cr...
Now take the template from the previously printed trailing edge curvature and trace it to the wings as shown. Next cut out along the curve line formi...
Now use the razor and cut the center fold as before, but this time only HALF of the length as shown by the RED line in the previous photo. This cut a...
This photo shows the exposed view of the center fold being cut halfway.This cut will allow the final fold for the leading edge of the CanardWings.cut ...
This is a shot from underside, your almost finished CanardWings should look like this.The stapled is bent slightly to create a dihedral and the staple...
Hold the CanardWings as shown in photo.To launch hold it above your head and lightly toss.This wings are great indoors and outdoors...tweak the traili...
Step 21: Video of CanardWing's long distance flight...
The CanardWings was launched from the 17th floor. The distance travelled was roughly 60~80 meters then caught the wind and was blown back a bit.It fl...
Step 16: Almost done...
Now spread open the center fold, this is what you should get: Spread it open
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
