3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cancakes - Mini Pancake cooker
Step 2Construction of the mini cooker
Firstly take your empty fruit tin and wash it thoroughly with hot water to remove any labels and glue.
Then create a ring of air-holes around the top of the cooker. These are vital, they allow air to flow upwards through the cooker. To make the holes simply pierce the tin with the skewer, taking care not to stab yourself, leave a 1/2" gap between each hole.
Cut a square access hole in the front of the cooker. This allows air in for combustion, and also where you light the candles from. Use the tin-snips to cut a square from the open end of the tin. If you wish to make the access hole safer, you can use pliers to turn the edges over as shown in the picture.
For best results, the candles should be no more than 4" from the cooking surface, so some cutting down of the can may be nessasary. Make sure that the cooker is stable before attempting to use it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:tz1_1zt
