A fun experiment combining simple electronics and common food stuffs. You'll need 4 cups of sugar, 2 cups of water, wire, electrical tape, assorted LEDs, paper cups, wax paper, a stove and a medium sized pot!
Step 1: Preparing the Sugar Syrup
Boil the 2 cups of water in the medium sized pot, adding the sugar 1 cup at a time and waiting for it to dissolve. It's important to keep stirring the pot and not to let the sugar cook too much or it will burn.
Step 2: Wrapping the LEDs
Take the LEDs, wire and electrical tape and wrap the wire around the leads, securing them with the tape. Wet the heads of the LEDs slightly and roll them in sugar to coat them and provide a base for the crystals to grow.
Step 3: Pouring the Syrup
After turning the sugar syrup off wait 5-10 minutes for it to cool, then pour it into either glass jars or paper cups. My first attempt was with glass jars but I found the crystallization took too long so I transfered the mixture to individual paper cups and that made it much easier. Wrap the ends of the wire around a pencil and lower it into the cups, adjusting the wire wraps to the height of the sugar line so that the head of the LED is totally immersed in the sugar.
Step 4: Unwrapping the Crystals
Set aside in a cool place away from direct light and wait 1-4 weeks, depending on how large you want the crystals to be. Peel off the paper cup from the sugar crystal and carefully break off the unconnected crystals from the main crystal formation around the head. Running it under warm water helps.
Step 5: Dry and Test
Set on a sheet of wax paper and allow to dry for a day or so. After completely dry, test with a 3V coin cell battery. You'll notice that the sugar helps diffuse and extend the luminosity of the LED to a much larger area.
Step 6: Play!
I'd advise you not to eat this experiment- LEDs are small enough to be accidentally swallowed so use caution if you do this experiment with kids. Have fun!
The_HandyMan says: Feb 19, 2013. 4:24 PM
nice job, will these rot go get sticky if i for say left them in my pocket
emdaniels (author) says: Feb 20, 2013. 7:24 AM
Most likely- it's sugar so if they are exposed to moisture and heat they'll melt a bit.
uberdum05 says: Oct 29, 2011. 10:21 AM
LED Lollipop?
ledsign says: Oct 26, 2011. 7:55 PM
It's very cool!
Thanks!
harry potter rules says: Oct 12, 2011. 8:20 AM
well done for winning the ipad 2!!!!!!!1
emdaniels (author) says: Oct 12, 2011. 9:07 AM
Thanks!
tato312 says: Sep 6, 2011. 2:18 PM
wow, those look cool, you have my vote! :D
emdaniels (author) says: Oct 7, 2011. 7:21 AM
Thanks tato312!
mrdz vela says: Sep 8, 2011. 10:45 PM
You got mine too, I can't wait to try it myself. Thank you!
Thanks mrdz vela!
bakesalot says: Oct 6, 2011. 6:51 PM
I've made rock candies but never thought to do them on lights! Really like this idea (:
emdaniels (author) says: Oct 7, 2011. 7:20 AM
Thanks! :)
Kaisei13 says: Sep 1, 2011. 6:11 PM
It defiantly wouldn't be edible, but I wonder if this would work with borax crystals?
emdaniels (author) says: Sep 6, 2011. 8:10 AM
Yes I think so- you could probably make one with epson salts too.
The Ideanator says: Sep 3, 2011. 4:18 PM
:O I want to make candied throwies for Halloween!
Gizah says: Aug 30, 2011. 3:26 PM
I really like the way they look, is there any way of conserving them to use them in an actual project? I mean, I guess they do get old and ugly eventually? Anyways, awesome instructable
emdaniels (author) says: Aug 31, 2011. 7:05 AM
Rock candy typically lasts anywhere from 8-24 months depending on humidity, temperature and packaging. If you are not planning to eat it I'm sure the shelf life is for as long as you can keep it away from water and high temperatures. It's sugar in it's purest form, so barring any food coloring that would most likely fade over time, the crystals should stay clear.
scoochmaroo says: Aug 29, 2011. 10:09 AM
This is amazing. I want to eat them.
emdaniels (author) says: Aug 30, 2011. 6:54 AM
Thank you scoochmaroo! They are probably fine to eat if you can get lead-free LEDs.
excaza says: Aug 30, 2011. 4:24 AM
This takes over the spot in my heart previously stolen by LED throwies. This is definitely the most creative use of LEDs I've ever seen!
emdaniels (author) says: Aug 30, 2011. 6:50 AM
Thanks excaza!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
