3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Candle-Like LED Lantern
Hello,
   Here is a way to create a great Candle-like Light inside a lantern or other light fixture. It makes a great Night Light, or used in a room to add a mysterious ambiance.
Items needed
1) Lamp purchased form most any Home Furnishing Store.
2) Several sheets of Tracing Paper.
3) 6-10 feet of 18/2 gauge Lamp Wire.
4) (1) Mini RGB Color Controller
5) (4) LED Splice Connectors
6) (1) foot of Amber LED Strip Light
7) (1) foot of Yellow LED Strip Light
8) (1) DC Wire Plug
9) (1) Inline Dimmer Switch
10) (1) 12V 12W Plug-in Adapter
11) Hot Glue Gun (with Hot Glue)
All of the LED Components (#'s 4-10) I was able to purchase from www.Elementalled.com
Step 1Connecting the Color Controller
Take the Positive, and negative wires from some 18/2 Lamp Wire, and Splice them into the positive, and negative Input Nodes on the Mini RGB Color Controller. This will supply the power to the Mini RGB Controller.
   Then splice together the positive lines on the two Splice Connectors, forming one positive wire to run to the RGB Controller. Screw that wire into the positive section of the RGB controller's 4-channels.
   Then take the two negative wires from the Splice Connectors, and screw them into two separate color channels on the Color Controller.
   Connect the Splice Connectors to the Strips by pulling the black tab out a little, sliding the strip into the slot, then pushing the tab back in.
5 comments
Jul 31, 2011. 10:32 AMtotszwai says:
Got a video on how it looks when it operates?
Jul 11, 2011. 1:24 PMMixMasterM says:
I like it. I've wanted to build a simulated 'lantern' for my patio, just like you've done here.
What store did get the lantern body from? I've found that most of the cool looking ones aren't cheap enough to use for a simple project. I'd like to hear where you found the lantern in this Instructable and how much it cost.
Also, the ElementalLED site doesn't show the Yellow LED strips -- only amber -- right now :^(
Overall, very nice. I might just use your write-up as inspiration to finally build my own "Pirates of the Carribean" lamp for sitting outdoors in the evening!
Jul 13, 2011. 12:19 PMMixMasterM says:
Yeah, I always want to work on ambiance lighting (flickering lights/etc.) after visiting DL or WDW. That bayou scene in DL's PotC so awesome. I'm very disappointed they dropped the ball on the WDW version, but that's another story...
Thanks for mentioning Ikea. We just got our first Ikea open in the entire state a few months ago, and it's a good distance from my house, so I'm not used to thinking of them for supplies or even knowing what they have. I'll have to go check it out sometime!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Zanibar
