Candle Holder From Upcycled Can
858
12
Posted in TechnologyReuse
Introduction: Candle Holder From Upcycled Can
About: I was born in the beautiful country called Romania in a nice city which has one of the most beautiful castles in the World: Corvin's Castle. Long story short: after I worked on an office job for 1.5 years ...
This is my first instructable.
I like to upcycle and recycle so I made a candle holder from a small corn can that I had.
Step 1: What You'll Need
You will need:
- one can (any size you want)
- one (whiteboard) marker
- one hammer
- one nail(or screw, or screwdriver or something sharp and made out of metal)
- paint
- brushes
- creativity
Step 2: Clean the Can
First you will need to clean the label off the can.
TIP: wash it with warm water while you scrub it with a knife or steel-wool
Step 3: Un-sharpen the Can
This is very important if you want your fingers uncut.
To do this, use the hammer(the narrow side of it) to bend the inside rim INWARDS.
Apply pressure while you bend the rim. Don't hit it with the hammer because it won't look smooth and rounded.
Have patience at this step, because I consider it very important.
After you've bent the rim, go a few times over it with the hammer while you apply pressure - not hitting! - so you make sure everything is smooth and un-sharp.
Step 4: Draw Your Pattern
In order for the candle holder to look nice and interesting, you'll have to make a pattern on it.
Using a white-board maker, draw your desired pattern on the can.
Step 5: Make the Holes
Using your nail(or screwdriver in my case) start punching the holes following your pattern(I failed at this step but it doesn't matter)
Step 6: Personalize It
Using the paint you have(or other stuff), decorate your new candle holder
Step 7: Enjoy It!
Put a candle in it, light it up and enjoy! :)
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Thank you, Penolopy! :)
    I will make new instructables soon, so keep an eye around ;)
