Candy Cane Marbled Monogram Ornaments
 by rchandsa
Contest WinnerFeatured
**   If you like this tutorial I would love it if you voted for me in the Holiday Gifts Contest.  Banner to vote on top right. **
I recently saw a marbleized nail technique on Pinterest and was so inspired to try it.  After several attempts I finally got the nail technique down and decided to do something more unique with it. Taking the glass ornaments that I purchased from Michael's Craft Supply, I created a water marble ornament.  You can check out my video tutorials on  how to marbleize an ornament and how to water marble nails.
For more simple unique crafts please visit me at http://thecheesethief.com/
Step 1:
Materials:
1 glass ornament
2 bottles of nail polish
1 vase/cup (large enough to fit half the ornament, but not too big) filled half way with filtered tap water
I used Orly French White and OPI All Lacquered Up for these images.  These nail polish brands seem to work the best for this technique.  Do experiment with different nail polishes as all of them do not work the same for this.
1. Prepare your workspace.  Place a towel or newspaper underneath for easier cleanup.
2. First shake both bottles of nail polish so the nail polish is nicely mixed.
3. Unscrew the tops of both bottles.  This will help you work fast.
4. Drip one color of the nail polish into the cup of water.
5. Drip the other color into the water and keep alternating.  (It is ok if the tip of the nail brush touches the water, but it is better if you can get a big glob to drip off the wand and drop onto the surface of the water.)
6. Working quickly alternate for 4-6 times.  If you are just starting off I would start with 4 -5 drips or rings.  When you get better you can do more.
7. Taking a toothpick start from the center of the nail polish and pull outwards to make a pattern.
8. It is easier to work from the inside out because the inside nail polish was just dripped so it is still wet.
Once you get the pattern you want dip your ornament in slowly for 10 seconds.  Remove and let dry ( i put it on top of a smaller cup).
Step 2: Monogrammed Ornament Instructions
For a monogrammed ornament cut the initial with tape.  Paint on clear nail polish first to seal the sticker seams (this will help with seeping).  If you want a more opaque monogram you can paint another base color over the monogram.  Follow the same instructions for water marbling.
Step 3:
Some tips for water marbling with nail polish.
1.  Use the smallest cup possible that will fit your ornament
2.  Experiment with different brands and colors of nail polish
3.  Use clean filtered room temperature water every time.
4.  if your polish seems to dry too fast, where when you drag the pattern it pulls the whole surface up, then try only swirling a pattern in the inner most rings
5. To help reduce water spots, dip ornament in slowly and blow off any water drops once ornament is lifted.  Avoid shaking the water too much also
6.  Work fast!
Step 4:
Klia Willow says: Oct 12, 2012. 8:40 PM
Jut wanted to tell you this is my next "kids" craft time christmas present for our family members. Every year my girls now 11 & 7 make a family gift for each member, me being a single mom it's always economical and everyone gets one, usually ornaments :) I LOVE this idea, both the marble & monogrammed, Thank you for posting!!
kabturek says: Jan 10, 2012. 12:14 AM
as always - it's harder than it looks ;-)
the important thing is the nail polish type - you cant do this with most.
Les Créateliers says: Dec 22, 2011. 6:30 PM
Love this tutorial!!!! I linked to it on my website:
http://www.lescreateliers.com/Les_Createliers/Idees_Ideas/Entries/2011/12/22_Boules_de_Noel_decoreesDecorated_ornaments.html
Hope you like it! Happy Holidays!!!
Marie-Eve
Celine1107 says: Dec 17, 2011. 5:17 PM
I tried doing this on my nails once and it didn't turn out to well, I tried for like an hour and it didn't work! I'm doing all the right things you are doing, I think I just can't get the pattern right.....oh by the way, I love the ornament! It's so pretty! Great instructible!
tandemquadrant in reply to Celine1107Dec 19, 2011. 9:39 AM
One of the best things to do is get a lot of nailpolish on the end of the brush so that it drips into the water instead of touching the brush itself to the water. When it drips, it spreads. And another tip is using the toothpick go from the inside out and doing opposite sides instead of adjacent sides will give you a bit more control :)
Celine1107 in reply to tandemquadrantDec 19, 2011. 11:31 AM
Thanks, those tips helped! I've figured out what I was doing wrong!
HollyHarken says: Dec 18, 2011. 7:28 AM
To get an even nicer pattern go from the middle out with your toothpick, alternating in between the places where you pulled the toothpick in towards the middle.
Very nice job on both the nails and the ornaments. Reminds me of marbleing on paper. Pretty.
Great idea using the lip balm to protect your finger!!
askjerry says: Dec 18, 2011. 6:47 AM
Nicely done... I had seen oil painting like this before... but the stencil idea is brilliant. I need to do this on some projects. We have a laser engraver... so we can cut a detailed pattern, then dip... can't wait to try it.
Thanks,
Jerry
jjone538 says: Dec 17, 2011. 5:33 PM
pretty
but where did u get the dotter tool
jjone538 says: Dec 17, 2011. 5:21 PM
awsome!!!!!
T Everette B says: Dec 14, 2011. 4:00 PM
The thought occured to me, could you do this with light bulbs too? it would make for some interesting light displays
hfuller in reply to T Everette BDec 16, 2011. 7:38 PM
Would the heat from the light bulb have any effect on the nail polish? It might make it bubble or melt.
rchandsa (author) says: Dec 15, 2011. 2:48 PM
Thanks for all your nice comments. If you like this tutorial I would love it if you voted for me in the Holiday Gifts Contest. Banner to vote on top right.
alyaika26 says: Dec 15, 2011. 9:36 AM
Good interesting article!
ChrysN says: Dec 14, 2011. 6:34 PM
What a cool effect, it looks gorgeous!
PaHalloweenFreak says: Dec 14, 2011. 4:45 PM
I have seen the nail technique before but never thought about using it for other things. Very creative! Great job on both the nails & the ornaments!
sailormoon22491 says: Dec 14, 2011. 4:20 PM
Wow that ornament is beautiful such a pretty effect!
mikeasaurus says: Dec 14, 2011. 3:26 PM
oooh, so that's how it's done!
l8nite says: Dec 14, 2011. 2:38 PM
really cool technique thank you for sharing
Penolopy Bulnick says: Dec 14, 2011. 1:46 PM
I just love that effect the nail polish has when it is on the water! Makes such a beautiful ornament!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
