Candy Cannon
Candy Cannon
A way to send halloween treats into the sky, without wadding or dangerous projectiles.
video
see the video. 3 sec. hang timefor the candy. container didn't leave the barrel because of loose seal.
Step 1First you need a large barrel potato gun.
This is the threaded end, where the fuel goes (I use ether). I added screws in addition to the ABS glue for extra strength, although it probably isn't necessary. It is also your access to the ignitor (see next step) and how you ventilate the cannon between shots, to get some fresh air inside quickly.
62 comments
1-40 of 62next »
Oct 18, 2009. 11:16 AMJakeg says:
so what do I use that makes it explosive. Is it just the air thats pressurized?
Jul 31, 2010. 1:18 AMJimmy Proton says:
hairspray is the most common but you can use most any flammable in a spray can
Nov 13, 2009. 2:06 PMColonel88 says:
"GTFO you crazy kids! *Shoots at the kids* There, you happy?!?"
Sep 28, 2009. 2:30 PMgeodez says:
i see i am supposed to aim it up instead of pointing it at them.
Jun 3, 2009. 6:45 PM7777777777 says:
where can I buy this cannon?
Sep 28, 2009. 2:28 PMgeodez says:
you have to build it, here is a link to a basic cannon, works very well.http://dangerouslyfun.com/spud-gun
Apr 16, 2008. 4:25 AMthefunktopus says:
whats a potato gun? could it be something that fires potatoes? where would i get one? Is there any way to mod this so it can fire rocks or small animals?
Mar 9, 2009. 12:19 PMWafflicious says:
Make one with PVC. Yes it can fire small animals but just not your little sisters pet mouse.
Oct 28, 2008. 7:31 PMThundertydus says:
hahahahahah wow the last line made me crap my pants laughing
Nov 7, 2008. 9:43 PMyeerk21 says:
i agree
Jun 29, 2008. 4:03 PMfinnster says:
how do you not know what a potato gun is
Aug 17, 2008. 8:00 PMBig Bubba says:
look at this Bad @$5 potatoe gun finn
Aug 21, 2008. 7:04 AMfinnster says:
lol haaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa haaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Aug 17, 2008. 7:56 PMBig Bubba says:
look at this one, thats bad-@$5
Aug 17, 2008. 8:03 PMBig Bubba says:
(removed by author or community request)
Dec 28, 2008. 6:28 PMT3hpw9ag3 says:
Jun 30, 2008. 8:31 AMthefunktopus says:
i thought they were small handguns
Mar 9, 2009. 12:15 PMWafflicious says:
those are spud guns
Jul 5, 2008. 8:11 AMfinnster says:
big foot duck can explain
Jun 11, 2008. 5:51 PMbigfootduck says:
a potato gun is a big cannon, about the same size as this cannon, but it launches potatos hundreds of feet. It is powered by a chamber full of hairspray. You stick the potato in, light the hairspray, and watch the potato burst through walls. I mad a mini one out of a chapstick container once. It was cool!
Jan 9, 2009. 9:53 AMDYLEGO says:
hairspray is for whimps! you need to go pneumatic if you want to go "hundreds of feet". A pneumatic potato cannon has an air chamber filled to 80-90 psi, and a sprinkler, ball, butterfly, or piston valve right after the air chamber. when you open the valve, the air pushes the projectile out the barrel.
Oct 18, 2008. 7:07 PMT3Hprogrammer says:
I've built a similar device and found that you can nearly double the range/power by putting the container in the other way (opening facing down.) This way the air pressure will expand it, making a better seal, rather than compressing it and creating leaks around the edges.
Oct 18, 2008. 3:13 PMkiss my donkey says:
bad @$$ potato gun
Sep 12, 2008. 12:41 PMjohnnyoh says:
I had encountered the wadding problem with my cannons as well. I found that a simple paper cup works if you mark the outside of the cup where it becomes snug in the barrel and then cut down to that point from the rim at the 12 3 6 and 9 o'clock points of the rim. Basically it functions much like a shotgun wadding and lands a few feet away.
Sep 11, 2006. 4:54 PMpaper warrior says:
use a beer can filled with concrete for ammo, you could probably knock down a tree or total a car
Aug 1, 2008. 6:42 PMbob the builder #1 says:
LOL
Jul 14, 2008. 8:30 AMtheosullis says:
My friend used gasoline instead of hairspray and the whole gun blew up in his hand and almost sent him to the ER. Just a moral, HAIRSPRAY IS YOUR FRIEND!
Sep 11, 2006. 2:59 PMzachninme says:
I would like it if someone could build a "nice" one... one that you can do inside... and won't kill innocent bystanders...
Aug 25, 2007. 12:17 AMadamazing says:
Prrrfft. In my experience, bystanders are rarely innocent.
Apr 2, 2008. 3:18 PMxproplayer says:
lol there could be a robber in a crowd dun dun dun lol
Sep 9, 2006. 7:22 AMCamster911 says:
Wow! Knock the children out by embedding hard boiled sweets in there sculls, nice one! :D
Sep 9, 2006. 2:01 PMUshanka says:
For the record, I launched lollipops out of a model rocket. Yeah, I got hit in the head with one falling from 500 feet. No, I did not crack my "scull". It's friggin CANDY. There's very little momentum and it's mostly prone to shatter if it hits something firm.
Dec 23, 2007. 5:54 AMjeffconnelly says:
yeah, try using it at a parade
Jul 13, 2007. 5:23 PMKayjay says:
not to mention the extra drag created because of the wrappers they arnt the best 4 aerodynamics
Sep 12, 2007. 2:52 PMknexgunner94 says:
lets make candy parachutes, then we could drop them from model airplanes
Oct 6, 2007. 7:50 PMfunwithfire325 says:
lol my uncle flies thoughs
Apr 2, 2008. 3:11 PMxproplayer says:
lol knock someone out with a good 15,000 feet of momentum
Apr 2, 2008. 4:40 PMUshanka says:
Nah, the candy will break before anything bad happens. The momentum will be about the same from 15,000 feet as it will from 150 feet. Candy is not very aerodynamic (Well, I suppose Tootsie Pops are pretty bullet-like) and it will have a slow terminal velocity. Combined with the small mass the momentum will be less than knock-someone-out strength. Moral: No Tootsie Pops. :P
Sep 14, 2008. 5:05 PMoctavian234 says:
what about jaw breakers?
Sep 10, 2006. 5:34 PMBad Donut says:
:D
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sparks
