Candy Stand Using Repurposed Plastic Bottles
Published
Introduction: Candy Stand Using Repurposed Plastic Bottles
About: Easy and affordable DIY projects and ideas.
I have no idea where the inspiration for this candy stand came from... I have a pile of cut plastic bottles that I regularly play with to think up ideas to use them, and this one just popped into my head. I think it would be perfect for a party table or special occasion, and could be used to display sweets or snacks.
If you want more recycling projects, pop onto www.Home-Dzine.co.za to see the lastest recycling crafts and ideas.
Step 1:
The base for the candy stand is a vinyl LP that I decided to put to good use, since I no longer have a record player. You could also use a cake tray, ceramic or glass plate, etc.
I used a 10mm HSS drill bit to enlarge the centre hole to fit a 10mm dowel for the stand.
Step 2:
You will also use the same drill bit to drill a hole in the centre plastic containers that will be mounted on the dowel.
Drill from the inside through the bottom - it's easier.
Step 3:
I pushed the containers onto the dowel and they fit nice and snug, but you can add a bit of epoxy glue if you need to.
This was very much trial and error to start off with, but I am very happy with how it turned out.
Step 4:
Before gluing everything into place, I sprayed each part with Rust-Oleum 2X satin blossom white.
I was going to leave it white but you will see that I changed my mind and sprayed it pink. I decided to go girly and over-the-top.
Step 5:
All the individual containers are glued onto the base using my Dremel Hot Glue Gun and glue sticks. I applied glue to the base of each container and lined them all up the same way. Place all the containers around the base so that you can ensure a nice fit and that each container touches the edge of the next one.
Once everything was stuck together nice and secure I took the stand outdoors and sprayed it with Rust-Oleum 2X gloss candy pink.
The new 2X cans have been formulated to spray onto plastic and it works like a dream.
Step 6:
Did I say I was going over-the-top? I used my glue gun to stick on some glittery silver butterflies here and there, as well as a few pink shimmering flowers.
Step 7:
As the final decorative touch I applied a thin bead of Bostik clear glue around the rim of each container and then sprinkled on some silver glitter.
Last item was to add a wooden bead on top as a handle and to finish off the candy stand.
Step 8:
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    9 Comments
    What a great idea. I never thought that this could be possible. I have a lot of soda bottle here.
    Excellent instructable! Thank you!
    I made something similar to Faberge eggs using chicken eggs. Must post this project. Blow out the eggs and use a dremel tool to cutout a design and then embellish.
    I love what they have done with bottles and if you use coloured plastic bottles you don't need to use ANY spray paint whatsoever - even more eco-friendly. Think I need to start drinking a different cold drink so I can use the coloured bottles...!
    Just a few days ago, I discovered EPBOT's jewelry stand made of Mt. Dew bottles (which are green so no need for paint) here-- http://www.epbot.com/2012/03/dew-it-yourself-jewelry-stand.html -- and was contemplating modifying the design for candy dishes. My idea was to use a 3-liter bottle on the bottom, facing up, to give it more capacity and stability, and use clear bottles with just the outsides (where there's no contact with the food) painted metallic gold. I wasn't certain on the food-grade quality of most spray paint (or the likelihood of it getting scratched in handling), so that was the reason for my idea of only painting the outsides.
    Very nice looking! I wonder with those gilded edges if something like a Fabrage' egg could be made from a pop bottle.
    Great idea!!! I love finding ways to repurpose things - next time I throw a baby shower I'll be sure to try this.
    This is so cool!!
    I'm definitely doing this the next time I have a party! :)
    xx
