So I decided to experiment with making a chocolate (candybar) powered rocket engine. A quick googling showed me that I was remembering right that people do make Sugar and Potassium Nitrate rockets. (And even pixi stick rockets), so I decided to see if i could do it too but using a candybar! (you know how many calories there are in them Right?
Figuring sticking with a space theme, and avoiding complex compounds such as peanuts. That a Milkyway candybar was just the ticket. (turns out that was a lucky decision, more on that later)
Remove these ads by
Signing UpStep 1: Materials,
- A small scale
- A hammer
- A grinder (mortar and pestle like i show here, or a coffee grinder you don't plan to use for food again)
- An anvil or chunk of steel or other hard object to pound on
- A Domed head carriage bolt (I believe the head size of mine was 3/4" and it was about 4" long)
- A drill, with, 7mm drill bit. and a counter sink drill bit, (or a larger 1/2" bit will do too.
- A permanent marker.
You Will need the following materials.
- Some clay kitty litter (a few ounces of clean clay based kitty litter will do) this will make the fire proof plugs at both ends of the engine
- A MilkyWay Candybar, this will provide the fuel
- Some Potassium Nitrate (salt peter) (as pure as you can get) Oxidizer,
- some thin wall PVC pipe (about the same internal diameter as the carriage bolt head), cut it into 2.5" lengths
- some cannon fuse, or model rocket engine igniter.
Visit Our Store »
Go Pro Today »
https://www.youtube.com/watch?v=5zNYMRaFS3M
& part2
https://www.youtube.com/watch?v=hzuX4Vw15HM
seriously melting sugar adding nitrates is a recipe for death or disfigurment or mangling and blindness. Adding water to the mix at any point is counterproductive. Look up old alt.fireworks and see their files. you buy tubes and clays and insert mold bore s. (all the wrong words, but they will make sense when you see how you make them. The mix is put in tubes you mold in nozzles, then you put in the part that makes the bore and it is on a platform that you "tamp down" (can you feel th esurgeons knife yet as she slices out the damaged eyesockets/), then you add parachute charge or flashover to next stage.
As a person with many many scars, you do this at your own risk, and from experience it is not worth the risk. I was almost killed and do not suggets you even try this.
Just pay the price and buy Estes. Safer ,Faster, most cost effective. (considering investment learning curve, medical costs legal fees etc.
If you live in the larger open places with next to NO NEIGHBORS, you can do high altitude rocketry. You will get visits from ATF and who know what other alphabet organization. Could get you a work offer or free trip to Gitmo.
buy the freaking things
Keep in mind that doing this wrong can produce a potential bomb. Overheating and casting with a crack are both dangerous failure modes.
More 'bang for your buck'
We made a bunch of these back in the day :)
Agree with the 'smoke was white when the mixture was right' from Krayfishkc !
Nice engine ! +++
PS. Don't try buying saltpeter, sulphur and carbon from your local chemists ! They don't like it ! lol
