loading
Step 5: Packing your jars
Pack tightly into jars, leaving about a 1 inch head space, I estimate this and it doesn't have to be perfect, just close.  Here's a bit skinnier pieces in a half pint jar, tightly packed.
I want to know when the pressure canned salmon expires? There has to be some sort time-frame after canning it.
<p>You should eat any canned foods within one year of canning it.</p>
<p>how much vinegar do u put in each jar when ur using 250 ml. jars</p>
<p>1 TEASPOON for PINTS (500 ml jars)</p><p>1/2 TEASPOON for HALF PINTS (250 ml jars)</p>
<p>do you get a &quot;pickled or vinegar&quot; taste to the salmon at all? wondering if i could soak the salmon in liquid smoke for a bit and then follow the recipe...thoughts from you? you seem to know what you're doing and this is my first time! thank you in advance!</p>
<p>None, no taste of vinegar at all. It just helps to soften the bones so you can eat them. I've put a few drops of liquid smoke into the jar and that taste okay too. Another way I can salmon is to bake the whole fish on a cookie sheet, save the juice when done. Strip all meat from the bones and skin and put the meat into the jars, add a few drops of liquid smoke, some salt and this taste delicious in a salad or straight from the jar.</p>
<p>I should add you can as usual in a pressure cooker.</p>
<p>Hey OhHeyLiana,</p><p>Maybe luck of the draw, but I have canned salmon for years, but each time, check the internet for up to specs canning info. My reason for checking in tonight was to conclude if I should can for 90 min, 100 min or 110 min. I traditionally use 90 min, as it is simple to remember, and I find the pressure drops really slow after 90 min is up and the heat is off. I have not been poisoned to date. I also usually use 12 lbs of pressure, but will switch to 100 min tonight, thanks to reading this thread.</p><p>This was the first link that came up with my key word search, and I saw your questions and thought I would reply. At the moment, I am canning 4 Coho salmon I caught earlier today. I prefer Sea Salt, but have used coarse pickling salt, table salt, kosher salt, and find they all work well. I will add a tip I have not heard mentioned. I have used vinegar before, but switched to lemon juice a long time ago. I prefer the favour, it dissolves the bones, and find it works just as well. I tend to go with RealLemon as it preserves colour and firmness.</p><p>Not sure how handy all are with a knife, but I will fillet my fish in a way to debone it, and I also remove the skin as well. Skinning the fish is very easy, and can be done by cutting through the flesh at a 45 degree angle, then pulling the fillet towards you while the blade of the knife does the work and cuts the fish along the fat, separating it from the skin. I get a great finished product, although my buddy reminds me that the bones are rich in calcium, while the skin has valuable nutrients. I find with the skin off the fish, I have less issues with residues sticking to the jar sides, and thus cleaning the jars for future use is easier.</p><p>Once your salmon is processed, jarred, sealed, and pressure cooked, it is ready to eat like canned salmon found from the store (but it will taste better). To tell if your cans sealed properly, you should hear popping sounds as they cool. To pressure test, once cooled, push down on the center of the jar lid, if it pushes back up and makes a kind of metallic &quot;pop&quot; or &quot;ping&quot;, it did not seal properly. It is pressure cooked, so place in the fridge and eat within a few days.</p><p>One final thought. I have canned smoked salmon, enjoy it, but it is labour intensive. I have family on the island and they use a product called &quot;Liquid Smoke&quot; to get the smoked salmon taste. I really like their product with the liquid smoke, but my family loves the salmon I make &quot;as is&quot;, so I do not use it.</p><p>Not sure on others canning experiences, but I used to can with Kerr brand lids, and had great success. In Canada, we now have lids made by Bernardin, and while they are porcelain coated (I believe), I have found the odd jar which may sit for some time, the white coating is etched by the acids in the jars. I believe the coating is intended more for fruit canning, and thus, if you can still find a lid made by Kerr in your area, it may be worth experimenting with these.</p><p>Hope this all helps! Have fun.</p>
<p>2 questions: <br><br>1. By Coarse salt do you mean pickling salt or will Sea Salt suffice? <br>2. I've never canned salmon or any other fish for that matter. Once it's processed and shelf stable - is it edible just by opening the can or do I need to cook it once I open the can since you packed it raw? <br></p>
We tried this last night with our Presto 23qt canner. Only half sealed.<br>Our elevation is around 1900 and most documents stated to can at 10lbs for 100min. Friends said they do 15lbs for 100 min...we used 15lbs would that make a difference? Or did we have too many jars? Our jars were not overfull...the ones on the right didn't seal.Any suggestions?
<p>LauraR8 you may have learned about this by now. but FYI: Internal canner pressures (and therefore temperatures) are lower at higher altitudes. Canners must be operated at increased pressures as the altitude increases. Check reliable canning instructions for altitude adjustments. I fish at sea level and thus don't really deal with elevation, but I live in Jackson Hole WY so if I were to can trout there, I would HAVE to increase the pressure. I love canning!!!</p>
It could be a number of reasons. How old are your lids? Although sometimes even new lids are bad right from the start. I've never canned anything at 15lbs so I don't know much about that. My elevation is only about 800 and you are more than double that, so maybe google and find out if that can make a difference. I would replace the lids and re-can, no harm in doing that at all and I hope you have better luck.
Everything was brand new (jars lids rings). As we finished late,(1am) we left the jars in the pressure canner all night.. i didnt think the unsealed jars would be good as they weren't refrigerated immediately after cooling. Then i get home tonight and 10 of them had sealed during the day...I don't know what to make of it lol.<br>Canning is a crazy business :)
Thank you so much for posting this information!!<br>I have been canning fish for over a decade and just wanted to add a few ingredients for people to try if they wish for something different<br>I have used numerous ingredients such as different peppers, garlic, onions etc<br>I find that my favorite is jalape&ntilde;o pepper slices added to seasoned fish such as salt or seasoning salt<br>I also add about a teaspoon of olive oil and have gotten into using either fish stock or chicken broth/stock<br>It keeps the fish very moist and have found that it gives the seasoning a chance to permeate through the meat. <br>I usually put enough to maintain enough head space of between an inch to 1.5 inches<br>I always cook between 12 - 15 lbs at 100 minutes <br>This ensures the bones are always soft<br>Enjoy!!!
Thanks for all the info AKCajun969! The only time I change is when I bake the salmon, strip all the skin and bones, pack into jars, adding the juice from when I baked plus a touch of liquid smoke and a bit of coarse salt... and then I process it at 10 lbs for 100 minutes. It's soooo good! I've tried adding other ingredients and I find it takes over the taste of the fish. I like the idea of using a bit of stock and will try that. :)
I did my first batch following your instructions. Great by the way. I have a few questions before I consume. First, the oil does not completely cover the meat in the can is this ok? Second, there are many little air pockets? Third, how tight, is &quot;pack tight&quot;? I pushed to the point where the flesh just started to smoosh. I just canned this today so air is not some sort of fermentation.
Sounds like you did a great job! Don't worry about the oil not covering all the meat, it will be fine.
<p>I like to add a split in half thai chill pepper to give it some heat and it masks any fishy smell.</p>
<p>I see you have two different sizes of All American pressure cookers. Could you tell me which sizes they are? Thanks!</p><p>Terry</p>
Thanks again. I think I will order the 921, it should fit our needs just fine.
I actually own four different sizes. The smallest I use is a 910 1/2 (it holds about 4 quarts), the most common one is a 921 (holds 7 quarts), I also have the taller version 930 (holds 7 quarts but is good for a double layer of pints), and I have the monster size 941. I use all of them, but the one I use most would be my 941, it holds about 19 quarts depending on the brands of the quart jars.
Kansasa, thanks for the quick reply! I need one that will work for canning salmon. I think the 921 is the smallest size for canning fish. Which size do you use for canning fish? Thanks!<br><br>Terry
<p>You can process fish in any size pressure cooker. The biggest jar I can my fish in is pints, although I did can in quarts a long time ago but it takes hours! In the 921 you can put in a double layer of pints with no problems. I usually can my fish in my 941 because I load it up with a ton of pint jars, but most people don't own that big of a pressure canner.</p>
Sorry, forgot to add, in the photo it's my biggest and smallest All-American, the 910 1/2 and the 941.
<p>HOW MUCH WATER DO I ADD TO A 20,8L (22 QUART) PRESSURE COOKER.....CANNING SALMON, 250ML JARS......12 JARS AT ONE TIME </p><p>Someone HAS to know !!!! ??? !!!!</p>
It doesn't matter at all what the size of the pressure cooker is or the size of the jars! You only add about an inch or so up the bottom layer of jars.... you NEVER cover the jars in water in a pressure cooker, unlike a hot water bath canner.
We canned a batch of salmon using our power pressure cooker xl for 30 minutes and was told that's not enough time. Is there any way we can re can them or are they no good.
Yes you can rebatch it! Just do it for 100 minutes at 10 lbs pressure and all should be good.
<p>Have u considered just putting bbq sauce in ur jars instead of cooking then canning- thus twice cooking! That's what I do!,</p><p>Wondering though- do u eat the skin? Maybe that's a stupid ? Idk!! I have always skinned it before canning but looking to can larger quantity so wanna save time!! Thanx!!</p>
<p>I'm not sure what you mean because I do raw pack and only cook once when it's canned. Yes, we eat the skin when it's done this way. It's usually mashed with a fork and mayo added and put in a sandwich or mashed and used for fish patties... once in a blue moon I will add it to a salad and gently flake it with a fork. Also the only time I've heard of using BBQ sauce is when people can't get real sockeye salmon and usually are covering up the taste of a cheap substitute such as chum or what we call &quot;humpies.&quot; </p>
<p>A few comments: </p><p>1: I like your Instructable; nice directions and photos. </p><p>2: I have never used vinegar when canning my salmon and have never had bones that did not soften to the point of being nearly unnoticeable when eating it; in fact, I take the backbones from the fish that were filleted and stuff them in the jars alongside the fish I am canning, thus utilizing the meat that is stuck to the bones and also adding more calcium to my food. </p><p>3. There is no need to cut the fins off; they will soften up and disappear into the meat. Also, there is fatty tissue around the base of each fin, making them more rich in omega 3 fatty acids.</p><p>4. I never remove scales. They also soften when canned.</p><p>5. last year I tried canning heads and was surprised at how well they turned out. They look pretty ugly in the jars and it was many months before I finally tasted them (because they looked so bad), but I found them to be delicious --better even than the plain meat. The only things that did not soften were the eyeball balls and the bigger teeth. This summer I plan to cut those out and then stuff half heads in between chunks of meat to make it look more appealing. </p><p>Most Westerners seem to throw away some of the best parts.</p>
<p>Wow... I have been looking for a homemade canned salmon recipe for years!!! My Grandmother used to make it... it was the best stuff on earth... no lie!!! Thank you to the moon and back!!! Am trying ASAP!!!</p>
Thanks Amazmerizing, I hope you enjoy it, we all do here. Let me know if you like it. :)<br>Kansas<br>
<p>i can not find pure white vinegar. can i use distilled vinegar instead? if so how much would i use? </p>
<p>Just a word about finishing after removing the jars from the pressure cooker.</p><p>We place our hot jars upside down onto a towel on the counter. Heat rises and this causes a tighter seal on the lid while cooling. When they cool down we remove the ring and clean up any spillage that might have occurred during canning. Then replace the ring ( finger tight only.)</p><p> Test the lids after jars have cooled by pressing down on them at the center. If they oil can ( you'll hear it ) reprocess or eat the contents soon.</p>
<p>I have pressure canned quite a few jars of salmon over the past week or so. Some of them turned out great but alas, a few of them the bones were not soft ~ could this mean that I didn't pressure can them long enough and if so ... can I re-pressure can them now? Thanks for the detailed instructions ... </p>
<p>I would think letting them sit longer and the bones would soften up because the vinegar has more to do with softening the bones than the time of the pressure canning. Yes you can redo them but I would add a touch more vinegar.</p>
<p>Thanks for your quick answer. Greatly appreciated!</p>
<p>Thanks for the detailed instructions &amp; the great photos. Can this technique be used for tuna?</p>
I don't know schworak, I've never tried tuna but I would imagine it would be okay.
<p>my husband just followed your recipe and ended up with lots of water in the jars. </p><p>Is that supposed to happen?</p>
<p>No there shouldn't be any water. Did he screw down the rings properly?</p>
<p>yes we both checked them. Now that it's cooled down the </p><p>water is down to 1/4 of the jar. I'm puzzled where it came from.</p>
<p>That sounds more normal, a little bit of water and oil is what you're supposed to have but not lots of water. I would say the water/oil comes from the fish.</p>
<p>we had the cut up fish in the fridge overnight</p><p>So it was cold when we did it.</p>
<p>Great instructions... but I have a stupid question... so after filling the jars with the fish and you have more jars then room in the cooker, can you put the jars in the frig? or do you only cut up as much fish for each bach. This takes alot longer to do than veggies, LOL, but I really want to can this year.</p>
I stick them in the fridge until they are ready for the next batch.
<p>thank you for this, I expect to do a fair amount of salmon as soon as my pressure cooker gets here from amazon, have you tried putting up cold smoked salmon since it does last as long as hot smoked does?</p>
<p>that is does not last as long as hot smoked</p>
<p>I don't can smoked salmon at all, rather I vacuum pack it and then freeze it. Sometimes I bake salmon, save the oil from the baking of it, strip off all the skin and bones, and add the meat to jars. Put in coarse salt, liquid smoke, and the saved oil. Process for 100 minutes in pressure cooker. It's very delicious but time consuming to remove all the skin and bones.</p>
About This Instructable
326,405views
54favorites
License:
More by kansasa:Whole Wheat Pizza Crust with fresh milled flour Cake Tip Octopus & Seaweed Lunch
Add instructable to:
