Canoe Paddle Clock
562
8
Posted
Introduction: Canoe Paddle Clock
A wooden canoe paddle made into a clock
Step 1: Cut Wood to Rough Length
Cut one piece of 3/4 inch thick cherry to 37" by 2" then cut that piece in half. Cut a thin strip of 37 by3/4 inch pine one blade thick to put in between your two pieces of cherry.
Step 2: Cut Paddle Pieces
Cut two pieces of 3/4 inch oak to 14 by 2 1/4 inches then cut a blade length right down the middle. Cut a blade length of cherry to place in the middle of the oak. Place the oak and cherry on the sides of the 37 inch cherry. Place two pieces of 1 by 3/4 inch oak on the opposite end of the paddle to create a handle glue all of your pieces together
Step 3: Plane
Plane your paddle so it is all the same height.
Step 4: Make It Look Like a Paddle
Trace out a paddle template onto your boards and cut it out. Round the handle to desired roundness. Give the fat part of the paddle a little roundness to it. Sand the paddle so it is as smooth as a baby's bottom.
Step 5: Drill and Route
Drill a hole in the middle so you can place your clock into it. Route the back of it to put the clock into the wood
Step 6: Polyurethane, Add Clock and Enjoy
Add 3 coats of poly on it and then put the clock and numbers on it.. Enjoy!!!!!!! :)
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
