Introduction: Canon Remote Shutter From Car Charger
Hi there, Today I will share all of you to make DIY Canon Remote Shutter from Car Charger.
The Equipment needed is :
1. Old Car Charger
2. Solder
3. Relay Button
4. Adapter 2,5 mm
Step 1: Open Car Charger
If you have old/used car charger do not throw it at garbage. You may make some DIY project like I did..
First Thing that you must open the car charger.. and cut the cable to small board, I used different picture of car charger to make it, cause i bought it just for almost  10.000 Rupiah (1 USD) for  4 Item.
Step 2: Solder the Cable
After you opened, solder it to Relay Button which is I show u bellow. make sure you have the good soldering.
Step 3: Put the Relay Into Casing
Try to put the relay button into car charger casing to have good handle when you pressed it. If you have a problem with the diameter relay button try to use hot iron to blend some of the plastic.. I did it... :)
Ooohhh.. sorry for ugly nails... do not fokus on it...
Step 4: Solder to Another Plug End
Solder the end plug to the middle  pin and the corner pin... pin between them ignore it. for further info please see the picture.
Step 5: Adapter Use
if you don not have 2,5 mm plug you may uses the adapter for it, just I did
Step 6: In Action
Plug the jack to shutter plug.. and ready to use.. you may halfpress to fokus the object and then full press to take a picture..
have a nice save and making portrait... if you think this instruction may be useful for your daily hobby, please vote for me..
Regards,
Muchlis
The Photography Contest
