Remove these ads by
Signing UpStep 1Parts
-Film Canister: This will serve as the body for the controller, after all, it is going to be used for taking pictures!
-Two-Way Switch: I had an old electronics kit from RadioShack that I took it from.
- 2 Submini Pushbutton Momentary Contact Switches: Purchased at RadioShack for about 3 bucks. Only pieces I had to buy.
-3/32" Stereo Jack Plug: I'll discuss this in the next step.
-Three Identical Lengths of Copper Wire: However long you want the cord to be.
-Meter w/ Continuity Test: Will come in handy when making connections later.
And then, some basic parts:
-Wire Cutter/Stripper
-Utility Knife or Scissors
-Soldering Iron and Stand
-Rosin Core Solder
-Heat Shrink Tubing
-Drill with Small Bits (I used a 3/16" bit to drill holes for the pushbutton switches)
-Electrical Tape
Thank you!
my recomendation
I put mine in an altoids gum tin.
Anybody have a spare 20D remote connector lying around?
Oh, and I don't really have a problem with EMI...even if there was some, it probably wouldn't cause any malfunctions with the control.
http://www.instructables.com/id/Remote-shutter-trigger-for-Canon-Cameras/
Make sure you add it to the photojojo contest!
