I've begun using this simple modification to make the stamped sizes stand out. Now I can quickly locate any size drill, socket or wrench no matter how they're tossed in my tool cabinet drawer.
Remove these ads by
Signing UpStep 1: What You'll Need:
2. Spray paint.
3. Acetone, paper towel and/or Scotchbrite.
Visit Our Store »
Go Pro Today »
As an aside, I don't suppose that really annoying flashing picture of Felix the Cat could be replaced with something else...? Maybe a picture of "what you'll need"?
The car I'm working on has both metric and imperial sized fittings, so your color coding idea would be perfect for that (it also uses every size that can be used with a denominator of "32"... I wonder if the bolts can be color coded for size as well).
Perhaps you can do an instructable on how you set things up?
Tell you what Spikolli, if you make an instructable (and let me know about it), I'll send you a year's pro membership... You'll have to remind me about my offer too... I forget easily. :)
http://www.instructables.com/id/When-a-Phillips-is-not-a-Phillips/
Enjoy.
Here was the comment I left on his Instructable, applies here also:
MyLEAST favorite screw head: The screws that are designed to take either a Phillips #3 or Robertson (square) drive. Some of the new timber construction fasteners, such as Spax, and some of the common bronze wood screws use this "combination" drive. It is my experience that tools designed to do two (or more) things do neither well.
Thanks for the heads-up. I'll research a little deeper.
Brilliant !
Thank you.
But Rimar2000 beat me to it regarding the drill bits! I also made a wood rack for my bits, with the sizes labeled. Should be a photo here. However, this is not foolproof. I have got the bits in the wrong place at times.
I also use this rack to select the correct bit for the screw size. I place the screw in several bit holes until the pilot hole size "seems right" for the screw.
Regarding drill bits, I fixed the problem –very annoying– to find the correct drill, when I decided to make a wood support. Each drill bit has its own hole, with its measure writed beneath with a sharpie.
http://i1207.photobucket.com/albums/bb468/pfred1/Keyholder.jpg
I don't know how much time that block of wood has saved me but I'd probably have to measure it on a calender now.
http://www.instructables.com/id/Make-a-Wrench-Organizer/
I keep most of my drill bits in index boxes, my sockets on rails, I have tool boxes dedicated to specific types of tools. I still misplace things now and again but for the most part what I need I can access immediately, if not sooner :)
Tossing all of your stuff in drawers with no method of organization is not worth the lack of effort it takes to do. At some point it has to become an esteem issue. I mean take some pride!
Over the summer I bought a bucket of assorted tools and the immediately I arranged what I'd gotten into sets. It only took me minutes to accomplish but has saved me from hours of frustration already. This is what came out:
http://i.imgur.com/EMHrC.jpg
This is some of it now:
http://i.imgur.com/nMwHj.jpg
Much more useful to me than everything tossed together. bfk I do use my tools all of the time and if I didn't keep them organized I'd never get anything accomplished.
