Step 4Cover half up and sew.
If your fabric is 60" or longer, layout the foam so that the fabrics can fold over it and cover it completely (the bad sad of the fabric should be facing up on top of the foam now). If it is only 38", then take one of your smaller pieces of fabric and cover the foam completely.
Pull the sides (and the top if need be) of the fabric tightly together and pin it in place. However, don't pin the two pieces together in the center of the larger piece. You are going to remove the foam through this opening after everything is pinned in place.
Once the foam is removed, sew along the line you just pinned (removing the pins as you go). Don't worry about reinforcing the stitching for now.
Add Comment
