Introduction: Capacity Test of Fake 18650
In this Instructables let's find the capacity of Fake 10400mAh Power bank.
Previously I used This power bank to make my own power bank because I bought it for $2.
To watch Video for this Project -
And don't forget to subscribe to my channel
So let's get started
Step 1: Opening
Let's first open the power bank
One's we have opened it cut the wires of power.
since there are 4 batteries and the total capacity is 10400mAh so the capacity of each battery is 2600mAh
Step 2: Charging
Battery was not fully charged so first charge.
let's first charge them using TP4056 module
Step 3: How to Calculate Capacity
We can simply use 1ohm 5 w resistor in series with the battery to test the capacity
but, voltage will decrease over the time and so our current ( resistance will be 1ohm)
and in this case we need to use integral function which is quite inaccurate
Step 4: LM358
Since using integral will be quite inaccurate let's use constant current source.
we can built a constant current source using LM358
let me explain how it works
1) When Vin is higher then Vref output is high which turns our MOSFET On
When MOSFET is trued on there is voltage drop across the resistor and our Vref is now High
2) When Vref is higher than Vin Output is Low and this cycle repeats
Step 5: Capacity Test !
One's the circuit is done adjust the potentiometer to get the current of 1A
It took 15 min for the battery to discharge completely.
Step 6: Calculation Time
Alringht so the,
Current was 1A
and time was 0.25 hr
so the capacity of the battrey is.....
250mAh
Step 7: My Thoughts !
I think they forgot to divide Every thingby 10
Because Actual capacity of the Power bank 1000mAh and not 10400mAh
And
The capacity of battrey is 250mAh and not 2600 mAh
Hopefully you like this project dont forget to like and share
And yes do check out my channel on Youtube - Click Here
(If there is Any Mistake Please feel free to tell me in comments)
