Step 11Add star
A star shape was drawn on the tape using a stencil. An exacto blade was used to cut away the needed areas, and the rest of the shield was masked off. The inner circle was then painted blue.
Painting this blue circle was especially tricky because the method used to seal up the tape in order to create clean lines and avoid bleeding only works if the tape is masking between two colors. Here, there were three colors I had to deal with all at the same time.
Before painting the blue coat, I very carefully spayed the edges of the taped star white, and the edge of the circle red. This sealed up the white star and the red circle from blue bleed-through. This worked very well and prevented any ugly bleeding.
6
comments
Add Comment
seamster (author)
says:
Add Comment
