3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Captain America Shield from used satellite dish
Step 2Draw circle
Draw circle
The satellite dish was an oval shape, and Captain America's shield is a round concave disk.
I was worried that a circle cut from the oval-shaped dish would look warped. But once it was cut out, the circle looked perfectly fine.
I eyeballed where the center of the dish was and put down three or four pieces of masking tape, which provided a place for the needle of my homemade compass to bite. I then drew as large a circle as would fit within the back lip of the dish.
2 comments
Dec 13, 2010. 2:19 AMHellwolve says:
When someone else reading this and for future projects...There's a neat little trick for getting the centre of a perfect(ish) circle some may not know. You need a machinist square or try square for it, ideally one with a 45 degree notch at the corner, plus a length of something straight, such as a ruler.
Push the circle into the corner made by your machinist/try square, add the straight length of whatever on top of your square, making sure it's at a 45 degree angle to the square, draw a line.
Turn the square/length contraption roughly 90 degrees, repeat. The crossing of the two lines will be the centre of your circle.
Basically you're creating a virtual square with sides that are equal to the diameter of the circle.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
465
Author:seamster
