Intro: Capture the Ethereal Beauty of Everyday Objects Using Polarized Light.
By using a pair of polarizing filters and a property of certain materials called birefringence we can photograph the hidden stresses in hard plastics....
A laptop or LCD monitor. LCD's have a built in polarizing filter, and will act as our light source.A polarizing filter to mount onto our camera.A trip...
In a darkened room. Turn on the laptop and create a white screen, I used clipboard on a Thinkpad 380 running win98, or you can create a white image in...
When we insert a hard plastic item into the field between the laptop and the camera, the birefringent property of the plastic causes the light's angle...
By using a pair of polarizing filters and a property of certain materials called birefringence we can photograph the hidden stresses in hard plastics. This instructable was inspired by this article and a comment I read in another instructable, somewhere, about LCD monitors and polarization.
Step 1: What you will need
In a darkened room. Turn on the laptop and create a white screen, I used clipboard on a Thinkpad 380 running win98, or you can create a white image in an editor and view it full screen. Mount the camera on the tripod and point it at the laptop screen, zoom in until the screen fills the camera's field of vision. If you haven't already, fit the polirizing filter onto the camera, slowly rotate the camera filter until the laptop screen goes black (you need to use the lcd on the camera, an optical viewfinder won't turn black ;-)). When the screen appears black from the camera's perspective we've achieved "cross polarization". Now we can start with the pictures.
Step 3: Taking the pictures
When we insert a hard plastic item into the field between the laptop and the camera, the birefringent property of the plastic causes the light's angle of polarization to change, since our light is no longer "cross polarized" it becomes visible again to the camera. And since different wavelengths have different refractive indices the visible light appears as a rainbow of colors. Exposures are on the order of 1/2 second so a stand should be used to hold the object.
Really nice instuctable!... If you have an old calculator LCD you don't even need the camera filter, you can peel the polarizer filter of that LCD an put it on the camera lens
This looks great :D I got a great affect with cellophane wrapping. I didn't have a polarising filter so i used one of the lens from 3D cinema glasses, and it works great :D
This doesn't work for JUST clear plastics, I remember my first Polaroid sunglasses and the effect of looking through automobile windows, etc. There is whole world of clear stuff to photograph :-)
I always find it incredible the wit people will employ to capture the true beauty of things. You've found a way to do this that's easy enough for everyone take advantage!
When did you realize that plastic in between two polarizing filters would achieve this effect? Learned or experimented? Either way, brilliant. Just brilliant.
if you can get a sheet of polarized plastic, you can set it in front of a light box, and use a second sheet in front of it. Just put the object you wish to view in between. My favorite is a clear disposable cup. You can see the stresses caused by the injection process. Also, try bending the objects and observe the stresses changing. Good for visualizing stress points in parts .
Ok, here are my first real attempts, not so good, but better than my others that had an extra filter on it ;-) The first one became blurry because I bumped the tripod....
Something that is hard to see in these since they've been downsized, on the second one it is more apparent however, although the stresses did not show up as colors in the upper portion of the bottle, it did show up as concentric (but not uniform) circular lines.
I purchased a pair of small "polarized'' filters and used a bottle cap (plastic) and a large plastic washer of sorts, to create my own little camera filter, that can be adjusted.
I am sure I followed all the directions above fairly closely, but the pictures below are all I am getting. Is this, by chance, because the filters are not only polarized, but also tinted?
BTW: the only thing that is really visible is the edge of my home made filter except in the first photo, where a faint outline of the top of a plastic water bottle can be barely made out).
The cap is a water bottle cap, and there is a space of about 3/4 of an inch between the filters, one is on a plastic ring that I have snapped onto the end of the cap, and the other filter is on the other end of the cap.
Oh, there's your problem, the item to be imaged has to be between the filters. Another consideration is some polarized filters only work in one direction because some contain a 1/4 wave retarder (it let's them work with digital cameras).
OH, bloody h 3 double match sticks...... Here I made the filter out of two polarized lenses......no wonder it didn't work......I will have to find some time to see if I can correct that and try again......thanks for getting my head on straight again :-)
Lovely stuff. I haven't thought about doing this since high school physics class when we were analyzing stresses, but I recall being fascinated by the aesthetics to the point of forgetting to record the results. Thank God I went into art and not engineering. If anyone has seen a 3-d movie lately, several seem to be using polarized (one eye vertical, one eye horizontal) glasses which can be fun for this sort of stuff if you pop out the lenses.
Only the serious movies / cinemas use polarization instead of the red/blue 3d effect. I haven't seen it anywhere other than iMax cinemas. I think it's because it's so much more expensive to produce than the red/blue 3d. If anyone has seen it in lotsa other places, go ahead and prove me wrong.
They use polarized glasses on the 4D adventure at Noah's Ark waterpark in the Wisconsin Dells. It's amazing how much better it is than the simple red/blue glasses - it really aids in making the effects realistic.
lol i typed IMAX like iPod... force of habit I see. well it may be different in USA, but here in gayass Australia (in my experience) they're not common. BTW I know ur American 'cos u said 'fall' instead of autumn like the rest of the planet
Heh, this is too much fun. I spent the better part of an afternoon experimenting. I found that glucose syrup in the bottom of that volumetric flask changes through a variety of colours depending on polarization axis.
I thought that this was very cool, and tried it out on my own. Here are a few pictures (taken with phone, camera battery was dead). i couldn't fit a filter to the phone, so i just held up a pair of polarized ray bans in front of the camera. i experimented with the white background, and decided that i could make just the polarization appear if it was white behind the plastic, and it wouldn't appear if it was behind a black background, and of course felt obliged to write "instructables" on it. the second used the negative effect of the camera, and the third is showing how the sunglasses filter the light
On a DSLR, the viewfinder sees through the lens, so it will work. the reason the viewfinder doesn't work on a point and shoot is that it doesn't see through the lens, but through a small hole above it, bypassing the polarizing filter.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
great instructable..5stars
