Bill of materials:
- Mint tin box or other enclosure
- LM317T regulator in TO220 package
- Heatsink for TO220
- Spare Notebook charger with 14V or more output
- 1 ohm, 2W resistor (I used 5W because that is what I had)
- #4-40 x 3/8" screws and 2 #4 nuts
- Wire
- Cigarette Lighter plug
Tools
- Solder
- Hot Glue Gun
- Soldering iron
- Dremel tool with abrasive cutoff wheel
- Drill with 1/8" bit
- Wire cutters n strippers
Remove these ads by
Signing UpStep 1Prepare the box
Gently bend the LM317 leads to a right angle
Align the mounting hole on the LM317 to one of the mounting holes for the heatsink
Mark a slot for the leads to pass through the lid. Cut this slot out with an abrasive cutoff wheel in a Dremel tool (High Speed rotary)
Use the rotary tol to cut a slot in both ends of the box bottom, and fold down. Close lid and make sure there is enough clearance for the cables to pass through the slots when the lid is indeed closed.
i used a computer power supply but it did not work
