Introduction: Car Battery Charger From Spare Parts in Mint Tin
Picture of Car Battery Charger From Spare Parts in Mint Tin
I needed a trickle charger for a seldom-used vehicle. Not wanting to spend money, I slapped this one together in about 30 minutes from parts lying around:
Bill of materials:
- Mint tin box or other enclosure
- LM317T regulator in TO220 package
- Heatsink for TO220
- Spare Notebook charger with 14V or more output
- 1 ohm, 2W resistor (I used 5W because that is what I had)
- #4-40 x 3/8" screws and 2 #4 nuts
- Wire
- Cigarette Lighter plug
Tools
- Solder
- Hot Glue Gun
- Soldering iron
- Dremel tool with abrasive cutoff wheel
- Drill with 1/8" bit
- Wire cutters n strippers
Step 1: Prepare the Box
Picture of Prepare the Box
Drill at least 2 holes in the lid to attach the heatsink and LM317T regulator
Gently bend the LM317 leads to a right angle
Align the mounting hole on the LM317 to one of the mounting holes for the heatsink
Mark a slot for the leads to pass through the lid. Cut this slot out with an abrasive cutoff wheel in a Dremel tool (High Speed rotary)
Use the rotary tol to cut a slot in both ends of the box bottom, and fold down. Close lid and make sure there is enough clearance for the cables to pass through the slots when the lid is indeed closed.
Step 2: Assemble and Wire
Picture of Assemble and Wire
Use the two # 4 screws and nuts to fasten the heatsink and LM317 to the top of the box, with the LM317 leads to pass through to the inside of the box.
Cut the power jack from the notebook power supply. This is usually a round ( barrel) plug which plugs into notebook). Strip and tim the leads.
Usually, the center wire is positive, but use a voltmeter to ensure this is true
Strip and tim the wires which will connect the regulator box to the auto power plug. I used 10 feet of 16 guage lamp cord because it was handly. long is good, as it allows the electronics to be placed out of the weather.
Wire the box per the schematic. Make sure to not have either of the pairs of wires to touch the metal box. The metal box is already connected to one of the pins of the LM317. Repeat, DO NOT WIRE ANYTHING TO THE METAL BOX.
Use generous amounts of hot glue to fasten down the resistor, the wire leads, the leads of the LM317, and the points where the leads pass in and out of the box.
Plug in the notebook power supply, and measure the voltage on the auto power plug. This needs to be 13.7V or more for proper operation. In the below pic, it is 16.16V, a relatively optimal voltage.
Step 3: Usage
This is a relatively crude charger. As it does not have a precise termination voltage, it should not be left on the batter indefinitely. An overnight charge should be about the limit.
Plug the power supply in, and plug the auto power plug into a cigarette lighter outlet in the car. YOu should notice the dome lights and everything become a bit brighter. Make sure everything is turned off, and leave the car for 2 to 12 hours, longer maybe for a totally dead battery
This power supply provides a contant current of 1.2A. Depending on the power supply voltage, this peak current will diminish somehwat as the battery approaches full charge
Step 4: Theory of Operation
The LM317 is normally used to create a constant voltage. In this application its behavior is exploited to create a contant current source. The LM317 regualtes int he following manner:
The device does whatever it can to keep the OUT pin exactly 1.2V higher than the ADJ pin. For example, if ADJ is shorted to ground, then OUT is 1.2V. In this application, we have connected a 1 ohm resistor from OUT to ADJ, and connected ADJ to the car battery. If the battery is 12V, then OUT pin of the LM317 is 1.2V greater, or 14.2V. Because there is a 1 ohm resistor from out to ADJ (and car battery), and there is 1.2V across this resistor, therefore 1.2A flows per ohms law
V = I * R ===> 1.2V / 1 ohm = 1.2A ( a bit of algebra here)
The LM317 will perform exactly as described as long as the following conditions are met:
- the input voltage of the LM317 must be about 1.5V greater than the OUT pin
- The LM317 does not overheat and go into self protection mode (hence the heatsink)
agis68 (author)2013-07-04
since you use the LM317 why don't make the specific ciruit for this job provided in the manufacturer datasheet?
ARJOON (author)2010-04-19
my question is. how much power input does the battery need to be input to charge.
i used a computer power supply but it did not work
imranaskari (author)ARJOON2010-08-25
-12v + +5v   make +17v which help u for charge battery
PLEASE do not use this circuit, it will ruin your battery, or worse. Use the circuit from the LM317 datasheet on page 21 titled "12V battery charger" (duh). The input voltage needs to be at least about 17V.
EricWilhelmSucksDick (author)2010-08-15
This is stupid. Why did you wire the LM317 as a constant current source? How about reading the freakin data sheet? How about actually using it as a 13,8V regulator, that you could leave hooked up to the battery indefinitely for float charging? If you ran the circuit in the schematic from a standard 19V laptop power supply, the output would be >16V, and the battery would produce LOTS of gas (hydrogen + oxygen). Nice way to blow up your house.
matstermind (author)2010-06-28
so, a. can this be used to charge a 12 volt electric scooter battery? and b. can i use a 1.2 ohm resistor?
Sethro (author)2009-07-15
" If the battery is 12V, then OUT pin of the LM317 is 1.2V greater, or 14.2V. " 14.2V? shouldn't it be 13.2? if the input for the LM317 needs to be 1.5V greater than the out (which is 13.2 or 14.2), The computer charger needs to be around 16 - 17 V. Mine puts out 19V. I have an extra 18V cordless drill charger that puts out 19V 2.2A, would this work in place of the comp cord?
FeedTheGrid (author)2009-04-24
Cool.
lemonie (author)2009-03-10
Do you actually need to regulate the voltage? What would happen if you just connected the notebook charger? L
NachoMahma (author)lemonie2009-03-10
. If you did that to a discharged battery, things would probably overheat. According to the author, the regulator is actually being used to control current (see Step 4). A schematic would probably go a long ways toward explaining it.
there is a crude schematic in one of the pictures
. Oops. Didn't notice that. And it's hard NOT to see.
The Speaker Guy (author)lemonie2009-03-10
A very high quality charger would provide a temperature-compensated regulated float voltage of about 13.6V. That however is somewhat difficult, and not necessary considering that 1.2A is really just a trickle. The idea was cheap and simple. Note this charger should not be left on indefinitely, as noted in the instructable.
lemonie (author)The Speaker Guy2009-03-10
Do you need the voltage to be regulated, or would the notebook charger work anyway? I'm asking because I don't know. L
guerroloco (author)2009-03-10
If you're not supposed to wire anything to the box, how come your schematic shows a wire connecting negative to "case"? And, the picture shows two wires soldered to the box. This matches your schematic but not your written instructions.
Good catch, I did make the mistake of soldering to the box, and I should know better. I subsequently unsodlered the wires from the box. That was easier than locating an isolating washer for the TO220 tab on the LM317.
About This Instructable
32,666views
56favorites
License:
More by The Speaker Guy:Car Battery Charger from Spare Parts in Mint TinBench Test AmplifierBristle Bot II - from a cheap electric toothbrush
Add instructable to:
